F1050防火墙为业务网关,ping测试业务后防火墙回复icmp type3 code 0
2021-09-26提问
  • 1收藏,1101浏览
粉丝: 关注:
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
设备型号:F1050
设备版本:version: 7.1.064, Release 9313P12
当前拓扑
221.208.164.10 访问 10.160.95.11 访问失败,通过ping测试 ,
当前收集的信息1
<4a-fw02>tracert -a 221.208.164.6 10.160.95.1 traceroute to 10.160.95.1 (10.160.95.1) from 221.208.164.6, 30 hops at most, 52 bytes each packet, press CTRL_C to break
 1 10.10.40.1 (10.10.40.1) 0.434 ms 0.304 ms 0.315 ms
 2 10.10.20.1 (10.10.20.1) 2.524 ms 0.846 ms 0.722 ms
双方路由没有问题,通过OSPF学习,中间的FW1 的2个接口在相同区域,应该没有问题,使用的测试是域间策略引用ACL的那种;
%Sep 26 12:48:22:193 2021 4a-fw02 FILTER/6/FILTER_ZONE_EXECUTION_ICMP: -COntext=1; SrcZoneName(1025)=IpAsDomain;DstZoneName(1035)=Trust;Type(1067)=ACL;Acl(1068)=2222;RuleID(1078)=0;Protocol(1001)=ICMP;SrcIPAddr(1003)=221.208.164.10;DstIPAddr(1007)=10.160.95.11;IcmpType(1062)=ECHO(8);IcmpCode(1063)=0;MatchCount(1069)=296;Event(1048)=Permit
也抓到策略允许通过的提升
但是在FW2上抓debug 发现网关回复icmp type3 code 0 的网络不可达信息 ,通过在221.208.194.11安装抓包软件 发现也是网关回复这个icmp type3 code 0
*Sep 26 10:00:02:206 2021 4a-fw02 IPFW/7/IPFW_PACKET: -COntext=1;
 Sending, interface = Vlan-interface611
version = 4, headlen = 20, tos = 0
 pktlen = 80, pktid = 40076, offset = 0, ttl = 255, protocol = 1
checksum = 7022, s = 221.208.164.6, d = 221.208.164.10 channelID = 0,
 vpn-InstanceIn = 0, vpn-InstanceOut = 0. prompt:
Sending IP packet from local at interface Vlan-interface611. Payload: ICMP type = 3, code = 0, checksum = 0x6163.
这边
但是感觉这边的会话应该是正常的
dis session table ipv4 protocol icmp verbose
 Slot 1:
Initiator:
 Source IP/port: 221.208.164.10/9
 Destination IP/port: 10.160.95.11/2048
 DS-Lite tunnel peer:
- VPN instance/VLAN ID/Inline ID: -/-/-
 Protocol: ICMP(1) Inbound interface: Vlan-interface611
 Source security zone: IpAsDomain
Responder:
 Source IP/port: 10.160.95.11/9
 Destination IP/port: 221.208.164.10/0
 DS-Lite tunnel peer: - VPN instance/VLAN ID/Inline ID: -/-/-
 Protocol: ICMP(1) Inbound interface: GigabitEthernet1/0/23
 Source security zone: Trust
State: ICMP_REPLY Application: ICMP Start time: 2021-09-26 01:22:16 TTL: 29s
Initiator->Responder: 52876 packets 3172560 bytes
Responder->Initiator: 52876 packets 3172560 bytes
相关配置
***.***/surl_yMAIpPfiNMG (提取码:5f94)​
设置列表
  • 有序列表
  • 无序列表
配置信息在附件里
粉丝:36人 关注:10人
最好是抓包看一下,ICMP差错报文是谁发的。
30Network Unreachable——网络不可达 x
是网关防火墙发的
发表时间:2021-09-26
知了小白
粉丝: 关注:
我的故障是  221.208.164.10无法访问10.160.95.11 ,发现网关回复 icmp type 3 code0 是我排查故障发现的但是不知道是不是他导致的,[污]   还是其他原因。排查不出来了
或者 有什么命令能查看数据包被没被防火墙丢弃?
各位大佬
发表时间:2021-09-26
链接:https://pan.baidu.com/s/1NPsqiovkGhyuJMs0GW8oZQ 提取码:1234 配置信息
发表时间:2021-09-26
粉丝:17人 关注:1人
说明网关防火墙没有到这个目的地址的路由。
<4a-fw02>tracert -a 221.208.164.6 10.160.95.1 traceroute to 10.160.95.1 (10.160.95.1) from 221.208.164.6, 30 hops at most, 52 bytes each packet, press CTRL_C to break 1 10.10.40.1 (10.10.40.1) 0.434 ms 0.304 ms 0.315 ms 2 10.10.20.1 (10.10.20.1) 2.524 ms 0.846 ms 0.722 ms 有的有的 双方网关ping测试 路由 teracer 都是可达的
发表时间:2021-09-26
回复:
那找一下这个包是谁发的,说明有设备一直发这个目的地址不可达报文,导致其他设备都认为目的不可达。
知什么了 发表时间:2021-09-26
网关发的
发表时间:2021-09-26
主要是由路由 而且双方网关 互ping都通, 路由没有问题,所以才纠结到底是不是网关导致的,
发表时间:2021-09-26
