s9512查看端口信息,类似 dis int命令
2021-10-14提问
  • 1收藏,1145浏览
粉丝:3人 关注:0人
1.1.7  display interface
display interface [ interface-type [ interface-number ] ]
【缺省级别】
1:监控级
interface-type:指定接口的接口类型。
interface-number:指定接口的接口编号。
【描述】
display interface命令用来显示指定接口当前的运行状态和相关信息。
l              如果不指定接口类型和接口号,则显示所有接口的信息;
l              如果仅指定接口类型,则显示所有该类型接口的信息;
l              如果同时指定接口类型和接口号,则显示指定接口的信息。
相关配置可参考命令interface
# 查看以太网接口Ten-GigabitEthernet5/1/2的运行状态和相关信息。
<Sysname> display interface Ten-GigabitEthernet5/1/2
 Ten-GigabitEthernet5/1/2 current state: DOWN
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e23f-32ce
 Description: Ten-GigabitEthernet5/1/2 Interface
 Loopback is not set
 Media type is not sure, Port hardware type is No Connector
Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled
 The Maximum Frame Length is 1552
 Broadcast MAX-ratio: 100%
 PVID: 1
 Link delay is 1(sec)
 Ethernet port mode: WAN
        J0(Rx):""
        00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00     *................*
        J0(Tx):""
        J1(Rx):""
        J1(Tx):""
     SDH error:
        section layer:  B1  0
        line    layer:  B2  0  M1  0
        path    layer:  B3  0  G1  0
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 1
 Port priority: 0
 Last 300 seconds input:  0 packets/sec 0 bytes/sec
 Last 300 seconds output:  0 packets/sec 0 bytes/sec
 Input (total):  0 packets, 0 bytes
          0 broadcasts, 0 multicasts
 Input (normal):  0 packets, 0 bytes
          - broadcasts, - multicasts
          0 ignored, - parity errors
          0 broadcasts, 0 multicasts, 0 pauses
 Output (normal): 0 packets, 0 bytes
          - broadcasts, - multicasts, 0 pauses
          0 aborts, 0 deferred, - collisions, 0 late collisions
          - lost carrier, - no carrier
表1-6 display interface命令显示信息描述表
以太网接口当前物理状态
以太网帧格式
Hardware address
接口硬件地址
描述信息
Loopback is not set
接口环回没有设置
Media typePort hardware type
导线类型,端口硬件类型
Unknown-speed mode
未知速度模式,速度由本机与对端设备协商决定
unknown-duplex mode
未知双工模式,双工模式由本机与对端设备协商决定
链路速度类型是自协商
链路双工类型是自协商
没有使用流量控制功能
接口允许接收的最大以太网帧长度
Broadcast MAX-ratio
最多允许广播报文占用接口流量的百分比
PVID
接口缺省VLAN ID
Link delay
链路UP/DOWN抑制时间
Ethernet port mode
以太网端口类型
SDH error
SDH的错误信息
Port link-type
接口链路类型(有access、trunk、hybrid三种)
Tagged   VLAN ID
标识在该端口有哪些VLAN的报文需要打Tag标记
Untagged VLAN ID
标识在该端口有哪些VLAN的报文不需要打Tag标记
Port priority
端口优先级
接口最后300秒的平均输入速率
接口最后300秒的平均输出速率
Input
输入报文
Output
输出报文
