IKE起来了,IPSEC没起来,
2021-10-26提问
  • 1收藏,1330浏览
IKE起来了,IPSEC没起来,设备到公网都是通的,请看看问题出在哪里
总部:
 interface GigabitEthernet0/0
ip address 202.1.1.1 255.255.255.0
 nat outbound 3000
 ipsec apply policy sh
# interface GigabitEthernet0/1
 port link-mode route
 combo enable copper
 ip address 192.168.10.254 255.255.255.0
 # ip route-static 0.0.0.0 0 202.1.1.254 #
 acl advanced 3000 description "NAT"
 rule 0 deny ip source 192.168.10.0 0.0.0.255 destination 192.168.20.0 0.0.0.255
 rule 5 permit ip #
 ipsec transform-set sh
 esp encryption-algorithm 3des-cbc esp
 authentication-algorithm md5
# ipsec policy sh 1 isakmp
 transform-set sh
 ike-profile sh
# ike identity fqdn bj
 # ike profile sh
 keychain sh
 exchange-mode aggressive
 match remote identity fqdn sh
 proposal 1 #
ike proposal 1
 # ike keychain sh
 pre-shared-key hostname sh key cipher $c$3$xnjT4ZikZ/ZopdbDuOfzuXrrW20veQ== # return
上海分部:
 ip address 192.168.20.254 255.255.255.0
# interface GigabitEthernet0/2
ip address dhcp-alloc
 nat outbound 3000
 ipsec apply policy bj
 # acl advanced 3000
 rule 0 deny ip source 192.168.20.0 0.0.0.255 destination 192.168.10.0 0.0.0.255
 rule 10 permit ip #
acl advanced 3001
 description "IPSEC"
 rule 0 permit ip source 192.168.20.0 0.0.0.255 destination 192.168.10.0 0.0.0.255
 ipsec transform-set bj
3des-cbc esp authentication-algorithm md5
# ipsec policy bj 1 isakmp
 transform-set bj
 security acl 3001
 remote-address 202.1.1.1
 ike-profile bj
# ike identity fqdn sh
 # ike profile bj
 keychain bj
 exchange-mode aggressive match remote identity fqdn bj
 proposal 1 # ike proposal 1
# ike keychain bj pre-shared-key address 202.1.1.1 255.255.255.255 key cipher $c$3$4SoG6f4OnnAejmyQUkPsgDQhXuISxQ==
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
粉丝:39人 关注:6人
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec  transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec  transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display  ike proposal
6、display  ipsec  transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
就是检查没有问题,才发出来咨询
zhiliao_vvynRh 发表时间:2021-10-26
