使用产品为:VSR1000,版本号为:Version 7.1.059, ESS 0323L03。
问题:
使用python语言的paramiko模块,通过ssh协议登录连接VSR设备时报错,提示: paramiko.ssh_excetion.SSHException:Channel closed。详细信息见截图。
测试脚本:
http://blog.51cto.com/chier11/2116155
(0)
其他厂家的网络产品和物理服务器的ILO系统等测试是正常的。使用python的telnet模块连接后执行命令是可行的。
同样的操作在华为防火墙上测试是正常的。操作结果和华为防火墙上debug信息如下:
>>>import paramiko
>>>sshcon=paramiko.SSHClient()
>>> sshcon.set_missing_host_key_policy(paramiko.AutoAddPolicy())
>>>sshcon.connect('192.168.55.130',22,'admin','password',compress=True)
>>>stdin,stdout,sterr=sshcon.exec_command('dis cpu')
>>>print stdout.read()
显示信息省略
>>>sshcon.close()
HRP_S<302-C13-513-FW-HWE1KE-001>debugging ssh server all all
16:06:25 2018/07/09
HRP_S<302-C13-513-FW-HWE1KE-001>terminal monitor
16:06:38 2018/07/09
Info: Current terminal monitor is on
HRP_S<302-C13-513-FW-HWE1KE-001> terminal debugging
16:07:02 2018/07/09
Info: Current terminal debugging is on
*16.1317533724 302-C13-513-FW-HWE1KE-001 SSH/7/FSM_MOVE:FSM moved from SSH_Main_Connect to SSH_Main_VersionMatch.
*16.1317533824 302-C13-513-FW-HWE1KE-001 SSH/7/RECV_VER:Received client version string:SSH-2.0-paramiko_1.7.7.1.
*16.1317533824 302-C13-513-FW-HWE1KE-001 SSH/7/SEND_PKT:Sent SSH2_MSG_KEXINIT packet.
*16.1317533824 302-C13-513-FW-HWE1KE-001 SSH/7/FSM_MOVE:FSM moved from SSH_Main_VersionMatch to SSH_Main_SSHProcess.
*16.1317533824 302-C13-513-FW-HWE1KE-001 SSH/7/RECV_PKT:Received SSH2_MSG_KEXINIT packet.
*16.1317533824 302-C13-513-FW-HWE1KE-001 SSH/7/KEX_DERECTION:Kex for direction is in.
*16.1317533824 302-C13-513-FW-HWE1KE-001 SSH/7/CHOOSE_ENCRYPT:Chose encryption algorithm:aes128-cbc.
*16.1317533824 302-C13-513-FW-HWE1KE-001 SSH/7/CHOOSE_MAC:Chose MAC algorithm:hmac-sha1.
*16.1317533824 302-C13-513-FW-HWE1KE-001 SSH/7/KEX_DERECTION:Kex for direction is out.
*16.1317533834 302-C13-513-FW-HWE1KE-001 SSH/7/CHOOSE_ENCRYPT:Chose encryption algorithm:aes128-cbc.
*16.1317533834 302-C13-513-FW-HWE1KE-001 SSH/7/CHOOSE_MAC:Chose MAC algorithm:hmac-sha1.
*16.1317533834 302-C13-513-FW-HWE1KE-001 SSH/7/CHOOSE_KEX:Choose Kex algorithm:diffie-hellman-group1-sha1.
*16.1317533834 302-C13-513-FW-HWE1KE-001 SSH/7/FSM_MOVE:FSM moved from SSH_Sub1_KEX_Init to SSH_Sub1_KEX_GRP_Reply.
*16.1317533934 302-C13-513-FW-HWE1KE-001 SSH/7/RECV_PKT:Received SSH2_MSG_KEXDH_INIT packet.
*16.1317533934 302-C13-513-FW-HWE1KE-001 SSH/7/SEND_PKT:Sent SSH2_MSG_KEXDH_REPLY packet.
*16.1317533934 302-C13-513-FW-HWE1KE-001 SSH/7/SEND_PKT:Sent SSH2_MSG_NEWKEYS packet.
*16.1317533944 302-C13-513-FW-HWE1KE-001 SSH/7/FSM_MOVE:FSM moved from SSH_Sub1_KEX_GRP_Reply to SSH_Sub1_KEX_NewKey.
*16.1317534044 302-C13-513-FW-HWE1KE-001 SSH/7/RECV_PKT:Received SSH2_MSG_NEWKEYS packet.
*16.1317534044 302-C13-513-FW-HWE1KE-001 SSH/7/FSM_MOVE:FSM moved from SSH_Sub1_KEX_NewKey to SSH_Sub1_Authentication.
*16.1317534144 302-C13-513-FW-HWE1KE-001 SSH/7/RECV_PKT:Received SSH2_MSG_SERVICE_REQUEST packet.
*16.1317534144 302-C13-513-FW-HWE1KE-001 SSH/7/SEND_PKT:Sent SSH2_MSG_SERVICE_ACCEPT packet.
*16.1317534144 302-C13-513-FW-HWE1KE-001 SSH/7/FSM_MOVE:FSM moved from SSH_Sub2_Service_Acc to SSH_Sub2_Auth_Init.
*16.1317534244 302-C13-513-FW-HWE1KE-001 SSH/7/FSM_MOVE:FSM moved from SSH_Sub2_Auth_Init to SSH_Sub2_Auth_Password.
*16.1317534344 302-C13-513-FW-HWE1KE-001 SSH/7/AUTH_AAA:The AAA authentication of user admin succeeded.
*16.1317534344 302-C13-513-FW-HWE1KE-001 SSH/7/FSM_MOVE:FSM moved from SSH_Sub1_Authentication to SSH_Sub1_Channel.
*16.1317584774 302-C13-513-FW-HWE1KE-001 SSH/7/RECV_PKT:Received SSH2_MSG_CHANNEL_OPEN packet.
*16.1317584774 302-C13-513-FW-HWE1KE-001 SSH/7/SEND_PKT:Sent SSH2_MSG_CHANNEL_OPEN_CONFIRMATION packet.
*16.1317584784 302-C13-513-FW-HWE1KE-001 SSH/7/FSM_MOVE:FSM moved from SSH_Sub1_Channel to SSH_Sub1_Session.
*16.1317584884 302-C13-513-FW-HWE1KE-001 SSH/7/RECV_PKT:Received SSH2_MSG_CHANNEL_REQUEST packet.
2018-07-09 16:11:32 302-C13-513-FW-HWE1KE-001 %%01SHELL/4/LOGIN(l): access type:ssh vsys:root user:admin login from 192.168.55.180
2018-07-09 16:11:33 302-C13-513-FW-HWE1KE-001 %%01SHELL/4/LOGOUT(l): access type:ssh vsys:root user:admin logout from 192.168.55.180
*16.1317673734 302-C13-513-FW-HWE1KE-001 SSH/7/RECV_PKT:Received SSH2_MSG_CHANNEL_REQUEST packet.
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
Python的telnet模块连接可以试想连接并执行命令。
