关键字
发布时间
WX3024 第二个SSID 分配不到DHCP
2017-07-27提问
  • 0收藏,884浏览
ac上开新开个SSID 拿不到DHCP
DHCP 池是做再核心上的
VLAN 10那个可以拿到DHCP
VLAN 11拿不到
AC配置
wlan service-template 1 crypto
 ssid ZJwinning
 bind WLAN-ESS 0
 cipher-suite wep40
 wep default-key 2 wep40 raw-key cipher $c$3$bBcuT4PguJ/YDQ9tElyS+S9HTPgSpz3RG2idZ2Y=
 wep key-id 2
 client-rate-limit direction inbound mode static cir 512
 client-rate-limit direction outbound mode static cir 2048
 service-template enable
wlan service-template 2 crypto
 ssid ZJwinning-guest
 bind WLAN-ESS 1
 cipher-suite wep40
 wep default-key 1 wep40 raw-key cipher $c$3$MikDIHOHTeGLC57sR++vTc47awhta62DHkCiaDY=
wlan ap-group default_group
 ap ap1
 ap ap2
 ap ap3
 ap ap4
 ap ap5
 ap ap6
 ap ap7
 ap ap8
 dot11a service-template 1
 dot11a service-template 2
 dot11bg service-template 1
 dot11bg service-template 2
 dot11a radio enable
 dot11bg radio enable
interface NULL0
interface Vlan-interface1
 ip address 12.12.12.10 255.255.255.0
interface Vlan-interface15
 ip address 192.168.15.1 255.255.255.0
 port link-type trunk
 port trunk permit vlan all
interface WLAN-ESS0
 port link-type hybrid
 port hybrid vlan 1 untagged
interface WLAN-ESS1
interface WLAN-MESH1
wlan ap ap1 model WA2612-AGN id 6
 serial-id 210235A35WC11B000075
 undo broadcast-probe reply
 radio 1
  channel 1
  radio-policy 1537
  service-template 1 vlan-id 11
  service-template 2 vlan-id 10
  mesh-profile 1
  bandwidth-guarantee enable
  radio enable
wlan ap ap2 model WA2612-AGN id 4
 serial-id 210235A35WC11B000071
 radio 1
  channel 6
  radio-policy 1025
  mesh-profile 1
  bandwidth-guarantee service-template 2 percent 100
  radio enable
wlan ap ap3 model WA2612-AGN id 5
 serial-id 210235A35WC11B000174
 radio 1
  channel 11
  radio-policy 1281
  mesh-profile 1
  radio enable
wlan ap ap4 model WA2612-AGN id 2
 serial-id 210235A35WC11B000146
 country-code CN
 radio 1
  channel 1
  radio-policy 513
  mesh-profile 1
  radio enable
wlan ap ap5 model WA2612-AGN id 1
 serial-id 210235A35WC11B000106
 radio 1
  channel 6
  radio-policy 257
  mesh-profile 1
  radio enable
wlan ap ap6 model WA2612-AGN id 3
 serial-id 210235A35WC11B000175
 radio 1
  channel 11
  radio-policy 769
  mesh-profile 1
  radio enable
——————————————————————核心————————————
这里VLAN
Interface            Link Protocol Main IP         Description
M-E0/0/0             DOWN DOWN     --
NULL0                UP   UP(s)    --
Vlan1                UP   UP       12.12.12.1
Vlan4                UP   UP       192.168.4.1
Vlan5                UP   UP       192.168.5.1
Vlan6                UP   UP       192.168.6.1
Vlan10               UP   UP       192.168.10.1
Vlan11               UP   UP       192.168.11.1
Vlan20               UP   UP       192.168.20.1
Vlan30               UP   UP       192.168.30.1
下面是DHCP池
Pool name: vlan40
 network 192.168.40.0 mask 255.255.255.0
 PrevSibling node:vlan4
 Sibling node:vlan5
 gateway-list 192.168.40.1
 dns-list 202.101.172.35 192.168.200.1
 expired 1 0 0
Pool name: vlan5
 network 192.168.5.0 mask 255.255.255.0
 PrevSibling node:vlan40
 Sibling node:vlan6
 gateway-list 192.168.5.1
 expired 1 0 0
Pool name: vlan6
 network 192.168.6.0 mask 255.255.255.0
 PrevSibling node:vlan5
 Sibling node:vlan10
 gateway-list 192.168.6.1
 expired 1 0 0
Pool name: vlan10
 network 192.168.10.0 mask 255.255.255.0
 PrevSibling node:vlan6
 Sibling node:vlan11
 gateway-list 192.168.10.1
 expired 1 0 0
Pool name: vlan11
 network 192.168.11.0 mask 255.255.255.0
 PrevSibling node:vlan10
 gateway-list 192.168.11.1
 expired 1 0 0
<CRsw>dis ip int b
*down: administratively down
————————————————-AC上的二层——————
这个二层应该没关系吧
<SH6D-SW-WX3024>dis vlan
 Total 4 VLAN exist(s).
 The following VLANs exist:
  1(default), 10-11, 15
将wep default-key 2改成wep default-key 1 应该就可以了,大部分终端只支持第一个缺省秘钥。
意思就是SSID 1 用 default-key 1 ssid2 用 default-key 2 是这样理解吗?
船到桥头自然沉 发表时间:2017-07-27
[AC-wlan-st-1]service-template enable Error: Wireless Service: ZJwinning-guest in [AP - ap7, Radio - 1] uses the same key-id 大大何解
行者 知了小白
很可能就是vlan透传问题 ac上 还有ac交换板卡上都要透传 检查一下看看是不是数据没做好
粉丝:35人 关注:4人
wlan service-template 2 添加 wep key-id 1 试试呢
可以这样尝试下 看看效果,WEP加密方式因为不安全性使用场景逐渐降低,换用wpa2方式的加密更加安全可靠
肉夹馍了解一下 发表时间:2017-07-27
AC上没WPA2 这个选项
(1) 配置AC # 启用端口安全。 <AC> system-view [AC] port-security enable # 配置无线端口安全,使用PSK认证方式,预共享密钥为12345678。 [AC] interface wlan-ess 10 [AC-WLAN-ESS10] port-security port-mode psk [AC-WLAN-ESS10] port-security preshared-key pass-phrase 12345678 [AC-WLAN-ESS10] port-security tx-key-type 11key # 创建服务模板10(加密类型服务模板),配置SSID为psktest,将WLAN-ESS10接口绑定到服务模板10。 [AC] wlan service-template 10 crypto [AC-wlan-st-10] ssid psktest [AC-wlan-st-10] bind WLAN-ESS 10 [AC-wlan-st-10] security-ie rsn [AC-wlan-st-10] cipher-suite ccmp [AC-wlan-st-10] authentication-method open-system [AC-wlan-st-10] service-template enable [AC-wlan-st-10] quit
肉夹馍了解一下 发表时间:2017-07-28
http://www.h3c.com/cn/Service/Document_Center/Wlan/WX/H3C_WX3000/Configure/Operation_Manual/H3C_CG(E3703P61_R2509P61_R3709P61)-6W108/02/201707/1012201_30005_0.htm 1.4 WLAN安全典型配置举例 1.4.1 PSK认证典型配置举例
好古老的加密方式,wep兼容性不好,建议使用wpa
没wpa 这个选项的 好古老的机器
船到桥头自然沉 发表时间:2017-07-28
标杆的神器激活
鼠年的运维 skr skr
