S5500V2-SI内的VLAN之间ping不通
2018-07-12提问
  • 1收藏,2262浏览
粉丝:1人 关注:1人
我这边有个三层交换机,创建好各VLAN之后,可以连接上联的防火墙上网。但是交换机之间的VLAN不能互通,配置如下,还想需要添加什么吗?
 version 7.1.045, Release 3116
 sysname H3C_701-3
 clock timezone Lisbon add 00:00:00
 clock protocol none
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 dhcp enable
 dns server 192.168.1.2
 lldp global enable
 password-recovery enable
vlan 1
 description Manager
vlan 3
 description VLAN 3
vlan 50
 description VLAN50
vlan 60
 description VLAN60
vlan 70
 description VLAN70
vlan 80
 description VLAN80
vlan 120
 description VLAN120
vlan 130
 description VLAN130
 stp global enable
dhcp server ip-pool 3
dhcp server ip-pool VLAN50
 gateway-list 172.18.5.1
 network 172.18.5.0 mask 255.255.255.0
 dns-list 192.168.1.2
dhcp server ip-pool VLAN60
 gateway-list 172.18.6.1
 network 172.18.6.0 mask 255.255.255.0
dhcp server ip-pool VLAN70
 gateway-list 172.18.7.1
 network 172.18.7.0 mask 255.255.255.0
dhcp server ip-pool VLAN80
 gateway-list 172.18.8.1
 network 172.18.8.0 mask 255.255.255.0
dhcp server ip-pool VLAN120
 gateway-list 172.18.12.1
 network 172.18.12.0 mask 255.255.255.0
dhcp server ip-pool VLAN130
 gateway-list 172.18.13.1
 network 172.18.13.0 mask 255.255.255.0
interface NULL0
interface Vlan-interface1
 ip address 192.168.2.3 255.255.255.0
interface Vlan-interface3
 ip address 172.18.2.4 255.255.255.0
interface Vlan-interface50
 ip address 172.18.5.1 255.255.255.0
interface Vlan-interface60
 ip address 172.18.6.1 255.255.255.0
interface Vlan-interface70
 ip address 172.18.7.1 255.255.255.0
interface Vlan-interface80
 ip address 172.18.8.1 255.255.255.0
interface Vlan-interface120
 ip address 172.18.12.1 255.255.255.0
interface Vlan-interface130
 ip address 172.18.13.1 255.255.255.0
 port access vlan 50
 port access vlan 50
 port access vlan 50
interface GigabitEthernet1/0/4
 port access vlan 60
interface GigabitEthernet1/0/5
 port access vlan 60
interface GigabitEthernet1/0/6
 port access vlan 60
interface GigabitEthernet1/0/7
 port access vlan 70
interface GigabitEthernet1/0/8
 port access vlan 70
interface GigabitEthernet1/0/9
 port access vlan 70
interface GigabitEthernet1/0/10
 port access vlan 80
interface GigabitEthernet1/0/11
 port access vlan 80
interface GigabitEthernet1/0/12
 port access vlan 80
interface GigabitEthernet1/0/13
 port access vlan 80
interface GigabitEthernet1/0/14
 port access vlan 80
interface GigabitEthernet1/0/15
 port access vlan 120
interface GigabitEthernet1/0/16
 port access vlan 130
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
 port access vlan 3
interface GigabitEthernet1/0/20
 port access vlan 3
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface Ten-GigabitEthernet1/0/27
interface Ten-GigabitEthernet1/0/28
 scheduler logfile size 16
line class aux
 user-role network-admin
line class vty
 user-role network-operator
line aux 0
line vty 0 63
 ip route-static 0.0.0.0 0 Vlan-interface1 192.168.2.1
 snmp-agent
 snmp-agent local-engineid 800063A28038ADBE5E887A00000001
 snmp-agent sys-info location 701_3
 snmp-agent sys-info version v3
acl number 2000
radius scheme system
 user-name-format without-domain
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user ADMIN class manage
 ip http enable
 ip https enable
return
寂东 九段
粉丝:225人 关注:3人
从配置上来看,是没问题的,首先要说明的是,三层交换机vlan间的互访,只要建立起相应的三层接口就行,不需要一个其他的命令或功能开通,他们是通过直连路由来实现的,从您的配置来看vlan50、60、70、80、120、130之间是可以互通的,您所说的不通,具体怎么访问的不通?截个图说着说明下,跨网段互访不通,问题不一定全部出在网络上,比如访问应用,应用是否启用?ping对方不通,防火墙是否开启拦截?最好的办法,找两台同一vlan内能ping通的主机,分别放在不同的vlan内,设置上相应的地址再测试ping,
谢谢大神您的回答,我知道了。配置是没问题的,发现这几天测试ping不通的原因有以下2个: 1、另一台电脑的防火墙没有关闭,所以不管是不是同一个VLAN都不能ping通; 2、刚开始我是直接ping那些VLAN的网关的,刚刚发现,其他VLAN的接口有有电脑接入才能ping通。意思就是说,我本机是 VLAN 50的172.18.5.2,其他VLAN 60、有电脑接入,才能ping得通 172.18.6.1 。无电脑接入就ping不通的。 最后还是非常感谢你啦,我也想成为像您这样的大神,从而帮助其他有需要的人,请问如何学习了解呀,谢谢指点一下
烟花里的尘埃 发表时间:2018-07-13
艾玛,让你这么一说,我好像进云端了,别摔死我,我可不是什么大神,就一个扫地、端茶倒水的,能帮助你很高兴,用我们所能做到的去帮助其他人,这是我的幸福,也感谢你对我的肯定,祝你好好学习,天天进步
寂东 发表时间:2018-07-13
paul 九段
粉丝:30人 关注:5人
交换机之间的VLAN不能互通,这个是指什么?举个例子吧
例如,我电脑用 VLAN 50 的172.18.5.2 ping不通 VLAN 60 的172.18.6.2的电脑。本网段是ping不通其他网段的网关的
烟花里的尘埃 发表时间:2018-07-12
粉丝:1人 关注:1人
唉,看来还是得自己技术硬才行,求人真难
