版本导入错了吧,设备型号是什么
(0)
H3C MSR20-10 BootWare, Version 5.10 下载的是MSR201X-CMW520-R2516P24.rar这个版本
#在设备启动过程中,当命令行界面出现“Press Ctrl+B to enter extended boot menu...”时,电脑立即键入<Ctrl+B>,按下<Enter>键后,系统将进入BootWare主菜单在BootWare主菜单下键入<3>,可以进入以太网口子菜单,系统显示如下:。
#键入<5>进入以太网口配置菜单
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :MSR2600-CMW520-R2516P19.bin
Target File Name :MSR2600-CMW520-R2516P19.bin
Server IP Address :192.168.1.2
Local IP Address :192.168.1.1
Gateway IP Address :0.0.0.0
#回到以太网菜单后,选择<2> 升级主应用程序,等待版本下载完成
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash |
|<1> Download Application Program To SDRAM And Run |
|<2> Update Main Application File |
|<3> Update Backup Application File |
|<4> Update Secure Application File |
|<5> Modify Ethernet Parameter |
|<0> Exit To Main Menu |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5): 2
Loading.....................................................................
..........................Done!
28075008 bytes downloaded!
Updating File flash:/MSR2600-CMW520-R2516P19.bin............................
...................................Done!
#选择<0> 返回上级菜单后,再选择<0> 重启设备。
Enter your choice(0-5): 0
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Clear Super Password |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
#设备已能正常启动,就表示版本已正常导入可以使用dis ver 查看
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
