华三 S5560S Version 7.1.045, Release 1109
2021-12-14提问
  • 1收藏,1051浏览
@me 零段
H3C  S5560S Version 7.1.045, Release 1109
交换机启用了VLAN 30 (172.16.30.0/24)  和VLAN31(172.16.31.0/24) 俩并在交换机接口配置对应的VLAN
1、VLAN 30与VLAN31 的用户无法ping通
2、部分客户的应用服务无法可以访问
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
交换机配置
[H3C]dis cu
# version 7.1.045, Release 1109
 # sysname H3C
# clock timezone Lisbon add 00:00:00 clock protocol none
# telnet server enable
# irf mac-address persistent timer undo irf auto-update enable undo irf link-delay irf member 1 priority 1
# dhcp enable # dns server 223.6.6.6
 # password-recovery enable
# vlan 1 # vlan 30 to 33
# dhcp server ip-pool vlan31 gateway-list 172.16.31.1 network 172.16.31.0 mask 255.255.255.0 dns-list 223.6.6.6 218.30.19.40 expired day 0 hour 2 netbios-type b-node
# dhcp server ip-pool vlan32 gateway-list 172.16.32.1 network 172.16.32.0 mask 255.255.255.0 dns-list 223.6.6.6 expired day 1 hour 2 netbios-type b-node
# interface NULL0
 # interface Vlan-interface30 ip address 172.16.30.2 255.255.255.0 undo dhcp select server # interface Vlan-interface31 bandwidth 1000000 ip address 172.16.31.1 255.255.255.0
# interface Vlan-interface32 ip address 172.16.32.1 255.255.255.0 undo dhcp select server # interface Vlan-interface33 ip address 172.16.33.1 255.255.255.0 undo dhcp select server
# interface FortyGigE1/0/29 port link-mode bridge
# interface FortyGigE1/0/30 port link-mode bridge
# interface GigabitEthernet1/0/1 port link-mode bridge bandwidth 1000000 port access vlan 30
# interface GigabitEthernet1/0/2 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/3 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/4 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/5 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/6 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/7 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/8 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/9 port link-mode bridge port access vlan 30
 # interface GigabitEthernet1/0/10 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/11 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/12 port link-mode bridge port access vlan 30
# interface GigabitEthernet1/0/13 port link-mode bridge bandwidth 1000000 port access vlan 31
# interface GigabitEthernet1/0/14 port link-mode bridge port access vlan 31
# interface GigabitEthernet1/0/15 port link-mode bridge port access vlan 31
# interface GigabitEthernet1/0/16 port link-mode bridge port access vlan 31
# interface GigabitEthernet1/0/17 port link-mode bridge port access vlan 32
# interface GigabitEthernet1/0/18 port link-mode bridge port access vlan 32
# interface GigabitEthernet1/0/19 port link-mode bridge port access vlan 32
# interface GigabitEthernet1/0/20 port link-mode bridge port access vlan 32
# interface GigabitEthernet1/0/21 port link-mode bridge port access vlan 33
# interface GigabitEthernet1/0/22 port link-mode bridge port access vlan 33
# interface GigabitEthernet1/0/23 port link-mode bridge port access vlan 33
# interface GigabitEthernet1/0/24 port link-mode bridge port access vlan 33
# interface M-GigabitEthernet0/0/0
# interface M-GigabitEthernet0/0/1
# interface Ten-GigabitEthernet1/0/25 port link-mode bridge
# interface Ten-GigabitEthernet1/0/26 port link-mode bridge
# interface Ten-GigabitEthernet1/0/27 port link-mode bridge
# interface Ten-GigabitEthernet1/0/28 port link-mode bridge
# scheduler logfile size 16 # line class aux user-role network-admin
# line class vty user-role network-operator # line aux 0 user-role network-admin
# line vty 0 4 user-role level-15 user-role network-operator set authentication password hash $h$6$iBAoqTxtG9BdVjeu$wuqVM0DZVjW+cniDoVkYAwILPPCkzeOwdYBCTnTqRn6C7VSuhSXTaWq/tSh91aXr7rtBMiveQ1JAhi+IZnSFqw== protocol inbound telnet
# line vty 5 63 user-role network-operator
# ip route-static 0.0.0.0 0 172.16.30.1
# snmp-agent snmp-agent local-engineid 800063A280487ADAC8453E00000001 snmp-agent sys-info contact 海量 snmp-agent sys-info location 陕西省西安市高新区软件园 snmp-agent sys-info version v3
# radius scheme system user-name-format without-domain
# domain system # domain default enable system
# role name level-0 description Predefined level-0 role
# role name level-1 description Predefined level-1 role
# role name level-2 description Predefined level-2 role
# role name level-3 description Predefined level-3 role
# role name level-4 description Predefined level-4 role
# role name level-5 description Predefined level-5 role
# role name level-6 description Predefined level-6 role
# role name level-7 description Predefined level-7 role
# role name level-8 description Predefined level-8 role
# role name level-9 description Predefined level-9 role
# role name level-10 description Predefined level-10 role
# role name level-11 description Predefined level-11 role
# role name level-12 description Predefined level-12 role
# role name level-13 description Predefined level-13 role
# role name level-14 description Predefined level-14 role
# user-group system # local-user admin class manage password hash $h$6$+dp+tb7cPcjDHaSG$9n8RNiHTa/95svGshH7G53iwTHUBKB3ErcsibAanj2/SrcQRCT2LwLooIYqqP1DvN3SHKIUtVZ7Qvk07xZJB0g== service-type http authorization-attribute user-role network-admin authorization-attribute user-role network-operator
# ip http enable
# return [H3C]
粉丝:10人 关注:1人
终端有没有配置网关?流通下丢包位置
客户的网关配置的交换机的VLANIP,访问非本交换机的网段是可以的
@me 发表时间:2021-12-14
