H3C 信息网巡检系统 SSH登录测试结果提示connection failed,108
2022-02-11提问
  • 1收藏,1625浏览
在巡检管家version 1.0.1 添加设备后,通过SSH登录测试提示connection failed,108.
但能够确定SSH配置是没有问题的,因为通过终端去登录是正常的,但通过巡检管家去登录就报这个,目前我有5-6台H3C设备都出现这个问题。
开启调试后SSH登录信息如下:
通过终端SSH登录正常:
*Feb 11 11:43:45:046 2022 H3C3640 SSHS/7/EVENT: Kex strings(5): umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-md5-etm@openssh.com,hmac-ripemd160-etm@openssh.com,hmac-sha1-96-etm@openssh.com,hmac-md5-96-etm@openssh.com,hmac-md5,hmac-ripemd160,hmac-ripemd160@openssh.com,hmac-sha1-96,hmac-md5-96
*Feb 11 11:43:45:046 2022 H3C3640 SSHS/7/EVENT: Kex strings(6): none,zlib@openssh.com,zlib
*Feb 11 11:43:45:046 2022 H3C3640 SSHS/7/EVENT: Kex strings(7): none,zlib@openssh.com,zlib
*Feb 11 11:43:45:046 2022 H3C3640 SSHS/7/EVENT: Kex strings(8):
*Feb 11 11:43:45:046 2022 H3C3640 SSHS/7/EVENT: Kex strings(9):
*Feb 11 11:43:45:047 2022 H3C3640 SSHS/7/EVENT: Kex: client->server, Encrypt: aes128-cbc, HMAC: hmac-sha1, Compress: none
*Feb 11 11:43:45:047 2022 H3C3640 SSHS/7/EVENT: Kex: server->client, Encrypt: aes128-cbc, HMAC: hmac-sha1, Compress: none
*Feb 11 11:43:45:050 2022 H3C3640 SSHS/7/EVENT: Expecting packet type 30.
*Feb 11 11:43:45:058 2022 H3C3640 SSHS/7/EVENT: Set new keys: mode=1
*Feb 11 11:43:45:059 2022 H3C3640 SSHS/7/EVENT: Expecting packet type 21.
*Feb 11 11:43:45:059 2022 H3C3640 SSHS/7/EVENT: Start new child 3905476.
*Feb 11 11:43:45:061 2022 H3C3640 SSHS/7/EVENT: Set new keys: mode=0
*Feb 11 11:43:45:061 2022 H3C3640 SSHS/7/EVENT: KEX done.
*Feb 11 11:43:45:062 2022 H3C3640 SSHS/7/EVENT: Received SSH2_MSG_SERVICE_REQUEST.
*Feb 11 11:43:45:063 2022 H3C3640 SSHS/7/EVENT: Received SSH2_MSG_USERAUTH_REQUEST.
*Feb 11 11:43:45:063 2022 H3C3640 SSHS/7/EVENT: Username: XXXX, service: ssh-connection, method: none
*Feb 11 11:43:45:064 2022 H3C3640 SSHS/7/EVENT: PAM: initializing for "XXXX", service:login, domain:
*Feb 11 11:43:45:145 2022 H3C3640 SSHS/7/EVENT: Try authentication method none.
*Feb 11 11:43:45:145 2022 H3C3640 SSHS/7/EVENT: Failed none for XXXX from 0.0.0.0 port 59877.
*Feb 11 11:43:45:145 2022 H3C3640 SSHS/7/EVENT: Get authentication methods: password
*Feb 11 11:43:45:647 2022 H3C3640 SSHS/7/EVENT: Received SSH2_MSG_USERAUTH_REQUEST.
*Feb 11 11:43:45:648 2022 H3C3640 SSHS/7/EVENT: Username: XXXX, service: ssh-connection, method: password
*Feb 11 11:43:45:648 2022 H3C3640 SSHS/7/EVENT: Try authentication method password.
*Feb 11 11:43:45:648 2022 H3C3640 SSHS/7/EVENT: Password authentication and authorization.
*Feb 11 11:43:45:654 2022 H3C3640 SSHS/7/EVENT: PAM: Get work directory cfa0:.
*Feb 11 11:43:45:654 2022 H3C3640 SSHS/7/EVENT: PAM: Get role list level-15,network-operator.
*Feb 11 11:43:45:654 2022 H3C3640 SSHS/7/EVENT: PAM: password authentication accepted for XXXX.
*Feb 11 11:43:45:654 2022 H3C3640 SSHS/7/EVENT: PAM: accounting.
*Feb 11 11:43:45:657 2022 H3C3640 SSHS/7/EVENT: PAM: account management : 0 (success)
%Feb 11 11:43:45:657 2022 H3C3640 SSHS/6/SSHS_LOG: Accepted password for XXXX from 0.0.0.0 port 59877.
*Feb 11 11:43:45:657 2022 H3C3640 SSHS/7/EVENT: Entering interactive session for SSH2.
*Feb 11 11:43:45:658 2022 H3C3640 SSHS/7/EVENT: Initiate server message dispatch, compatibility:1/0
*Feb 11 11:43:45:658 2022 H3C3640 SSHS/7/EVENT: Received SSH2_MSG_CHANNEL_OPEN: ctype session, rchan 0, win 1048576, max 16384
*Feb 11 11:43:45:659 2022 H3C3640 SSHS/7/EVENT: Received session request.
*Feb 11 11:43:45:659 2022 H3C3640 SSHS/7/EVENT: Channel 0: new [server-session]
*Feb 11 11:43:45:659 2022 H3C3640 SSHS/7/EVENT: Session id 0 unused.
*Feb 11 11:43:45:659 2022 H3C3640 SSHS/7/EVENT: Session opened: session 0, link with channel 0
*Feb 11 11:43:45:660 2022 H3C3640 SSHS/7/EVENT: Received SSH2_MSG_CHANNEL_REQUEST: channel 0, request pty-req, reply 1
*Feb 11 11:43:45:661 2022 H3C3640 SSHS/7/EVENT: Channel request: user XXXX, service type 2 rtype:pty-req
*Feb 11 11:43:45:671 2022 H3C3640 SSHS/7/EVENT: Open pty: pseudo-terminal-master(35), pseudo-terminal-sub(34)
*Feb 11 11:43:45:672 2022 H3C3640 SSHS/7/EVENT: Received SSH2_MSG_CHANNEL_REQUEST: channel 0, request env, reply 0
*Feb 11 11:43:45:672 2022 H3C3640 SSHS/7/EVENT: Channel request: user XXXX, service type 2 rtype:env
*Feb 11 11:43:45:672 2022 H3C3640 SSHS/7/EVENT: Received SSH2_MSG_CHANNEL_REQUEST: channel 0, request shell, reply 1
*Feb 11 11:43:45:672 2022 H3C3640 SSHS/7/EVENT: Channel request: user XXXX, service type 2 rtype:shell
*Feb 11 11:43:45:674 2022 H3C3640 SSHS/7/EVENT: PAM: opening session.
*Feb 11 11:43:45:677 2022 H3C3640 SSHS/7/EVENT: Setup environment: user=XXXX, work directory=cfa0:
*Feb 11 11:43:45:678 2022 H3C3640 SSHS/7/EVENT: Get default work dir: cfa0:, return:0
%Feb 11 11:43:45:678 2022 H3C3640 SSHS/6/SSHS_CONNECT: SSH user XXXX (IP: 0.0.0.0) connected to the server successfully.
*Feb 11 11:43:45:686 2022 H3C3640 SSHS/7/EVENT: Channel 0: read_fd 37 is a TTY.
%Feb 11 11:43:45:846 2022 H3C3640 SHELL/5/SHELL_LOGIN: XXXX logged in from 0.0.0.0.
但是通过巡检系统去SSH 登录就不行
*Feb 11 11:44:53:465 2022 H3C3640 SSHS/7/EVENT: Connection from 1.1.1.1 port 13066
*Feb 11 11:44:53:467 2022 H3C3640 SSHS/7/EVENT: Client protocol version 2.0, client software version H3C-GatherTool
*Feb 11 11:44:53:467 2022 H3C3640 SSHS/7/EVENT: Enabling compatibility mode for protocol 2.0
*Feb 11 11:44:53:467 2022 H3C3640 SSHS/7/EVENT: Local version string SSH-2.0-Comware-7.1.059
*Feb 11 11:44:53:468 2022 H3C3640 SSHS/7/EVENT: Hostkey string is : ssh-rsa
*Feb 11 11:44:53:469 2022 H3C3640 SSHS/7/EVENT: Start new child 3905513.
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Received SSH2_MSG_KEXINIT.
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: My proposal kex:
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(0): diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(1): ssh-rsa
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(2): aes128-cbc,aes256-cbc,3des-cbc,des-cbc
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(3): aes128-cbc,aes256-cbc,3des-cbc,des-cbc
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(4): hmac-sha1,hmac-sha1-96,hmac-md5,hmac-md5-96
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(5): hmac-sha1,hmac-sha1-96,hmac-md5,hmac-md5-96
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(6): none,zlib,zlib@openssh.com
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(7): none,zlib,zlib@openssh.com
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(8):
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Kex strings(9):
*Feb 11 11:44:53:512 2022 H3C3640 SSHS/7/EVENT: Peer proposal kex:
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(0): diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(1): ssh-rsa
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(2): aes128-cbc,3des-cbc,des-cbc
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(3): aes128-cbc,3des-cbc,des-cbc
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(4): hmac-sha1-96,hmac-sha1,hmac-md5,hmac-md5-96
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(5): hmac-sha1-96,hmac-sha1,hmac-md5,hmac-md5-96
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(6): none
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(7): none
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(8):
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex strings(9):
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex: client->server, Encrypt: aes128-cbc, HMAC: hmac-sha1-96, Compress: none
*Feb 11 11:44:53:513 2022 H3C3640 SSHS/7/EVENT: Kex: server->client, Encrypt: aes128-cbc, HMAC: hmac-sha1-96, Compress: none
%Feb 11 11:44:53:562 2022 H3C3640 SSHS/6/SSHS_LOG: Connection closed by 1.1.1.1.
粉丝:14人 关注:4人
是不是SSH版本太低了?巡检管家应该支持SSH 2.0以上的版本。
我的巡检管家版本version1.0.1.我查看了下几台交换机的SSH版本都是2.0,我添加了ssh 兼容后就能登录成功了。
zhiliao_hVXKMb 发表时间:2022-02-11
粉丝:3人 关注:0人
格式有问题   手动加上呢
