AOM采集器部署失败
2022-03-10提问
  • 1收藏,1055浏览
具体错误信息为docker , Error response from daemon: driver failed programing external connectivity on endpoint splus,probe_servere (179e662a8b5f724bbedBe37b54c846d2e653862fc50538428250691e618f6e3): iptables failed:iptabies -wait nat -A DOCKER -p tcp -d 0/0-dport 48519 -j DNAT .to-destinstion 172.18.0.9:48519 1 -i br-345776c26e42: iptables: No cha in/target/match by that name.(exit status 1)).
然后就一直显示Container cdbcdc3433a91fb9e55c8ba4e3ca3f10da47fa8415f6ac6c914586714474982e is not running,最后重启probe容器时会报错,报错内容是Error response from daemon:Cannot restart  container splus_probe_server0:dricer failed programing external connectivity on endpoint splus_probe_server0 (49d903c8f7f94741dbcc35fb42573d88c963cd013c78bdc39a0d83820c78c0):iptables failed:iptabies -wait nat -A DOCKER -p tcp -d 0/0-dport 48519 -j DNAT .to-destinstion 172.18.0.9:48519 1 -i br-345776c26e42: iptables: No cha in/target/match by that name.(exit status 1)).
应该是主机的防火墙关闭导致iptables规则写入失败了,检查一下防火墙状态
