内部服务器放在192.168.1.164,局域网内其他地址可以访问。在防火墙中添加了内部服务器转发后,外网仍旧不能访问。
GigabitEthernet0/0 ,接内网
GigabitEthernet0/1 ,接外网
version 5.20, Release 5142P02
sysname H3C
undo voice vlan mac-address 0000-bb00-0xx0
interzone policy default by-priority
domain default enable system
telnet server enable
undo alg dns
undo alg rtsp
undo alg h323
undo alg sip
undo alg sqlnet
undo alg pptp
undo alg ils
undo alg nbt
undo alg msn
undo alg qq
undo alg tftp
undo alg sccp
undo alg gtp
session synchronization enable
password-recovery enable
acl number 2000
rule 0 permit
vlan 1
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
pki domain default
crl check disable
interface NULL0
interface GigabitEthernet0/0
port link-mode route
interface GigabitEthernet0/1
nat outbound
nat server protocol tcp global current-interface 8080 inside 192.168.1.169
www
ip address 218.15.198.186 255.255.255.248
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
ip address 192.168.2.1 255.255.255.0
vd Root id 1
zone name Management id 0
priority 100
import interface GigabitEthernet0/0
import interface GigabitEthernet0/1
zone name Local id 1
priority 100
zone name Trust id 2
priority 85
zone name DMZ id 3
priority 50
zone name Untrust id 4
priority 5
switchto vd Root
ip virtual-reassembly
zone name DMZ id 3
ip
route-static
load xml-configuration
load tr069-configuration
user-interface con 0
user-interface vty 0 4
authentication-mode scheme
return
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
方便加我QQ吗804452201
对不起,不太方便远程,上班时间,不太方便
