内网有两个vlan,分别为vlan10和vlan20,然后我想让vlan10是通过外网链路100.0.0.0/24去访问1.1.1.1;让vlan20是通过外网链路200.0.0.0/24去访问1.1.1.1,配置如下,麻烦帮你看一下是否可行,好像没有做成功。
[H3C]dis cu
vlan 1
vlan 10
vlan 20
policy-based-route 1 permit node 10
if-match acl 3000
apply next-hop 100.0.0.2
policy-based-route 2 permit node 10
if-match acl 3001
apply next-hop 200.0.0.2
interface Vlan-interface10
ip address 192.168.10.1 255.255.255.0
ip policy-based-route 1
interface Vlan-interface20
ip address 192.168.20.1 255.255.255.0
ip policy-based-route 2
interface GigabitEthernet0/1
port link-mode route
combo enable copper
ip address 100.0.0.1 255.255.255.0
nat outbound
interface GigabitEthernet0/2
combo enable copper
ip address 200.0.0.1 255.255.255.0
nat outbound
interface GigabitEthernet6/0
port link-mode bridge
port access vlan 10
combo enable copper
interface GigabitEthernet6/1
port access vlan 20
combo enable copper
ip route-static 0.0.0.0 0 100.0.0.2
ip route-static 0.0.0.0 0 200.0.0.2
acl advanced 3000
rule 0 permit ip source 192.168.10.0 0.0.0.255
acl advanced 3001
rule 0 permit ip source 192.168.20.0 0.0.0.255
return
[H3C]
(0)
应该配置是正确的 你是怎么测试的 tracert吗?
(0)
模拟器无法测试的,之前在真实的环境配置测试了一次
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
