交换机一直提示以下信息,该信息是什么原因导致的?对网络是否有影响?应该如何解决?
%Jan 8 20:10:51:256 2013 H3C-S5560-ST_2F-HJ STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.
%Jan 8 20:10:54:088 2013 H3C-S5560-ST_2F-HJ STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.
%Jan 8 20:10:55:266 2013 H3C-S5560-ST_2F-HJ STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.
%Jan 8 20:10:58:086 2013 H3C-S5560-ST_2F-HJ STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change.
(2)
检查当前交换机下的二层聚合 口1下的端口成员 是不是有哪个端口在up/down。把该接口的线路整理好就可以好了。
(0)
什么型号的设备?可以收集display diag信息,然后查看display stp tc信息,看哪个端口收到的tc报文多,然后一直沿着对应的接口往下查吧。
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
如果有UP down的情况是不是因为环路?
