http://www.h3c.com/cn/d_201904/1173273_30005_0.htm#_Toc7106093
按照上面的链接做的,但是bfd session 为down,不知道什么原因
(0)
[R1]dis cu
version 7.1.064, Release 0821P11
sysname R1
bfd echo-source-ip 3.3.3.3
track 1 bfd echo interface GigabitEthernet0/1 remote ip 46.46.1.1 local ip 46.46.1.2
track 2 bfd echo interface GigabitEthernet0/2 remote ip 46.46.2.1 local ip 46.46.2.2
ip unreachables enable
ip ttl-expires enable
system-working-mode standard
xbar load-single
password-recovery enable
lpu-type f-series
vlan 1
policy-based-route pbr permit node 10
if-match acl 2001
apply next-hop 46.46.1.1 track 1
policy-based-route pbr permit node 20
interface Serial1/0
interface Serial2/0
interface Serial3/0
interface Serial4/0
interface NULL0
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0
port link-mode route
combo enable copper
ip address 192.168.3.2 255.255.255.0
ip policy-based-route pbr
combo enable copper
ip address 46.46.1.2 255.255.255.0
nat outbound 2003
bfd min-echo-receive-interval 100
bfd detect-multiplier 3
combo enable copper
ip address 46.46.2.2 255.255.255.0
nat outbound 2003
interface GigabitEthernet5/0
combo enable copper
interface GigabitEthernet5/1
combo enable copper
interface GigabitEthernet6/0
combo enable copper
interface GigabitEthernet6/1
combo enable copper
scheduler logfile size 16
line class aux
user-role network-operator
line class console
user-role network-admin
line class tty
line class vty
line aux 0
line con 0
line vty 0 63
ip route-static 192.168.1.0 24 192.168.3.1
ip route-static 192.168.2.0 24 192.168.3.1
acl number 2001
rule 5 permit source 192.168.1.10 0
acl number 2002
rule 5 permit source 192.168.2.10 0
acl number 2003
rule 5 permit
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
return
[R1]
(0)
这个是配置,放这了,上传不上去
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
