[SZZGS-U200S]dis cur
[SZZGS-U200S]dis current-configuration
version 5.20, Feature 5123P31
sysname SZZGS-U200S
super password level 3 cipher G`M^B<SDBB[Q=^Q`MAF4<1!!
l2tp enable
undo voice vlan mac-address 00e0-bb00-0000
domain default enable system
telnet server enable
ip http port 8008
acl number 2000
rule 0 permit
vlan 1
domain system
authentication ppp local
access-limit disable
state active
idle-cut disable
self-service-url disable
ip pool 1 172.32.10.101 172.32.10.110
pki domain default
crl check disable
user-group system
local-user admin
password simple admin
authorization-attribute level 3
service-type lan-access
service-type portal
local-user user
password cipher %P2+BGQR;PCQ=^Q`MAF4<1!!
service-type telnet terminal
service-type ppp
local-user vpdnuser
password simple 123456
service-type ppp
ssl server-policy access-policy
pki-domain default
l2tp-group 1
undo tunnel authentication
allow l2tp virtual-template 1
tunnel name LNS
interface Virtual-Template1
ppp authentication-mode chap domain system
remote address pool 1
ip address 172.32.10.253 255.255.255.0
interface NULL0
interface Vlan-interface1
interface GigabitEthernet0/0
port link-mode route
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/1
nat outbound 2000
nat server protocol tcp global 183.93.159.11 8800 inside 172
nat server protocol tcp global 183.93.159.11 52060 inside 17
nat server protocol tcp global 183.93.159.11 8888 inside 172
nat server protocol tcp global 183.93.159.11 52064 inside 17
nat server protocol tcp global 183.93.159.11 52062 inside 17
nat server protocol tcp global 183.93.159.11 ftp inside 172.
nat server protocol tcp global 183.93.159.11 554 inside 172.
nat server protocol udp global 183.93.159.11 5060 inside 172
nat server protocol udp global 183.93.159.11 52062 inside 17
nat server protocol tcp global 183.93.159.11 52061 inside 17
nat server protocol tcp global 183.93.159.11 5540 inside 172
nat server protocol tcp global 183.93.159.11 www inside 172.
nat server protocol tcp global 183.93.159.11 8081 inside 172
nat server protocol tcp global 183.93.159.11 8089 inside 172
nat server protocol udp global 183.93.159.11 1701 inside 172
nat server protocol tcp global 183.93.159.11 9901 inside 172
nat server protocol tcp global 183.93.159.11 9902 inside 172
nat server protocol tcp global 183.93.159.11 9903 inside 172
ip address 10.2.20.218 255.255.255.0
interface GigabitEthernet0/2
ip address 172.32.1.2 255.255.255.0
interface GigabitEthernet0/3
interface GigabitEthernet0/4
ip route-static 0.0.0.0 0.0.0.0 10.2.20.254
ip route-static 172.32.1.0 255.255.255.0 172.32.1.1
ip route-static 172.32.2.0 255.255.255.0 172.32.1.1
ip route-static 172.32.3.0 255.255.255.0 172.32.1.1
ip https ssl-server-policy access-policy
ip https enable
load xml-configuration
load tr069-configuration
user-interface con 0
authentication-mode password
set authentication password cipher G`M^B<SDBB[Q=^Q`MAF4<1!!
user-interface vty 0 4
return
[SZZGS-U200S]
为什么我的admin 账号不能web 登录啊
(0)
没有 web,
[SZZGS-U200S-luser-admin]ser
[SZZGS-U200S-luser-admin]service-type ?
ftp FTP service type
lan-access LAN-ACCESS service type
portal Portal service type
ppp Specify user type to ppp
ssh Secure Shell service type
telnet TELNET service type
terminal TERMINAL service type
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
