F5030版本升级遇到这种情况怎么恢复啊?
  • 1收藏,882浏览
This application is not correct, please select a right version. BOM:0235A2B3
============================================================================= This application is not correct, please select a right version.BOM:0235A2B3 System will be restarting... ============================================================================= System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU... Press Ctrl+T to start heavy memory test.. Booting Normal Extended BootWare The Extended BootWare is self-decompressing....Done. **************************************************************************** * * * H3C SecPath BootWare, Version 1.08 * * * **************************************************************************** Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. Compiled Date : Jul 16 2020 Memory Type : DDR3 SDRAM Memory Size : 16384MB Flash Size : 8MB sda0 Size : 3728MB CPLD Version : 2.0 PCB Version : Ver.A BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Loading the main image files... Loading file sda0:/F5080FW-CMW710-SYSTEM-R9628P2416.bin............
粉丝:219人 关注:0人
您好,设备故障,走售后流程吧
粉丝:143人 关注:1人
重新刷个版本
