S6825-54HF IPv4 traffic statistics:无数据
2022-08-06提问
  • 1收藏,593浏览
粉丝:2人 关注:8人
S6825-54HF 交换机查看接口dis int Twenty-FiveGigE 1/0/53 为什么IPv4 traffic statistics无数据呢
粉丝:7人 关注:0人
查看接口流量吗
截图方便粘下不,可以计算
wenty-FiveGigE1/0/53 Current state: UP Line protocol state: UP IP packet frame type: Ethernet II, hardware address: b845-f485-4f6a Description: To_ADDC_collector Bandwidth: 10000000 kbps Loopback is not set Media type is optical fiber, port hardware type is 10G_BASE_SR_SFP Ethernet port mode: LAN 10Gbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 9416 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 88 MDI type: Automdix Port link-type: Access Tagged VLANs: None Untagged VLANs: 88 Port priority: 0 Last link flapping: 10 weeks 1 days 18 hours 42 minutes Last clearing of counters: Never Current system time:2022-08-06 16:19:17 Beijing+08:00:00 Last time when physical state changed to up:2022-05-26 21:36:59 Beijing+08:00:00 Last time when physical state changed to down:2022-05-26 21:33:55 Beijing+08:00:00 Peak input rate: 23 bytes/sec, at 2022-05-26 23:53:27 Peak output rate: 2915105 bytes/sec, at 2022-08-06 16:13:01 Last 300 seconds input: 0 packets/sec 12 bytes/sec 0% Last 300 seconds output: 20639 packets/sec 2852934 bytes/sec 0% Input (total): 788320 packets, 68539336 bytes 78 unicasts, 3 broadcasts, 788239 multicasts, 0 pauses Input (normal): 788320 packets, - bytes 78 unicasts, 3 broadcasts, 788239 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, 0 throttles 0 CRC, 0 frame, - overruns, 0 aborts - ignored, - parity errors Output (total): 48708949 packets, 6681825556 bytes 45867132 unicasts, 3 broadcasts, 2841814 multicasts, 0 pauses Output (normal): 48708949 packets, - bytes 45867132 unicasts, 3 broadcasts, 2841814 multicasts, 0 pauses Output: 0 output errors, - underruns, 0 buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, - no carrier IPv4 traffic statistics: Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec Input: 0 packets, 0 bytes Output: 0 packets, 0 bytes IPv6 traffic statistics: Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec Input: 0 packets, 0 bytes Output: 0 packets, 0 bytes
051805180518 发表时间:2022-08-06
麻烦查看一下 下一条评论
粉丝:2人 关注:8人
Current state: UP
Loopback is not set
PVID: 88
MDI type: Automdix
Tagged VLANs: None
Untagged VLANs: 88
Port priority: 0
Last 300 seconds input: 0 packets/sec 12 bytes/sec 0% Last 300 seconds output: 20639 packets/sec 2852934 bytes/sec 0% 可以看这个 input 没有
zhiliaoy 发表时间:2022-08-06
