有没有快捷键关闭terminal monitor 功能
2022-08-10提问
  • 1收藏,1416浏览
粉丝:3人 关注:0人
除了 undo terminal monitor
有快捷键关闭terminal monitor功能吗,如ctrl+o关闭debug一样
粉丝:94人 关注:0人
display hotkey
display hotkey命令用来显示系统支持的快捷键及其含义。
display hotkey
# 显示系统支持的快捷键及其含义。
<Sysname> display hotkey
----------------- Hotkeys -----------------
           -Defined command hotkeys-
CTRL_G display current-configuration
CTRL_L display ip routing-table
CTRL_O undo debugging all
           -Undefined command hotkeys-
CTRL_T NULL
CTRL_U NULL
           -System-reserved hotkeys-
CTRL_A  Move the cursor to the beginning of the line.
CTRL_B  Move the cursor one character to the left.
CTRL_C  Stop the current command.
CTRL_D  Erase the character at the cursor.
CTRL_E  Move the cursor to the end of the line.
CTRL_F  Move the cursor one character to the right.
CTRL_H  Erase the character to the left of the cursor.
CTRL_K  Abort the connection request.
CTRL_N  Display the next command in the history buffer.
CTRL_P  Display the previous command in the history buffer.
CTRL_R  Redisplay the current line.
CTRL_V  Paste text from the clipboard.
CTRL_W  Delete the word to the left of the cursor.
CTRL_X  Delete all characters from the beginning of the line to the cursor.
CTRL_Y  Delete all characters from the cursor to the end of the line.
CTRL_Z  Return to the User View.
CTRL_]  Kill incoming connection or redirect connection.
ESC_B   Move the cursor back one word.
ESC_D   Delete all characters from the cursor to the end of the word.
ESC_F   Move the cursor forward one word.
ESC_N   Move the cursor down a line.
ESC_P   Move the cursor up a line.
ESC_<   Move the cursor to the beginning of the clipboard.
ESC_>   Move the cursor to the end of the clipboard.
表1-4 display hotkey命令显示信息描述表
已定义的快捷键
未定义的快捷键
系统保留的快捷键。每个保留快捷键的作用请参见表1-5
表1-5 系统保留的快捷键
快捷键
功能
<Ctrl+A>
将光标移动到当前行的开头
<Ctrl+B>
将光标向左移动一个字符
<Ctrl+C>
停止当前正在执行的功能
<Ctrl+D>
删除当前光标所在位置的字符
<Ctrl+E>
将光标移动到当前行的末尾
<Ctrl+F>
将光标向右移动一个字符
<Ctrl+H>
删除光标左侧的一个字符
<Ctrl+K>
终止呼出的连接
<Ctrl+N>
显示历史缓冲区中的下一条命令(暂不支持)
<Ctrl+P>
显示历史缓冲区中的上一条命令
<Ctrl+R>
重新显示当前行信息
<Ctrl+V>
粘贴剪贴板的内容
<Ctrl+W>
删除光标左侧连续字符串内的所有字符
<Ctrl+X>
删除光标左侧所有的字符
<Ctrl+Y>
删除光标所在位置及其右侧所有的字符
<Ctrl+Z>
退回到用户视图
<Ctrl+]>
终止当前连接
<Esc+B>
将光标移动到左侧连续字符串的首字符处
<Esc+D>
删除光标所在位置及其右侧连续字符串内的所有字符
<Esc+F>
将光标向右移到下一个连续字符串之前
<Esc+N>
将光标向下移动一行(输入回车前有效)(暂不支持)
<Esc+P>
将光标向上移动一行(输入回车前有效)(暂不支持)
<Esc+<>
(暂不支持)将光标所在位置指定为剪贴板的开始位置
<Esc+>>
(暂不支持)将光标所在位置指定为剪贴板的结束位置
·     hotkey
1.1.10  hotkey
hotkey命令用来为快捷键指定对应的命令行。
undo hotkey命令用来恢复缺省情况。
hotkey { ctrl_g | ctrl_l | ctrl_o | ctrl_t | ctrl_u } command
undo hotkey { ctrl_g | ctrl_l | ctrl_o | ctrl_t | ctrl_u }
<Ctrl+G>对应命令display current-configuration(显示当前配置)。
<Ctrl+L>对应命令display ip routing-table(显示IPv4路由表信息)。
<Ctrl+O>对应命令undo debugging all(关闭设备支持的所有功能项的调试开关)。
<Ctrl+T>未关联任何命令行。
<Ctrl+U>未关联任何命令行。
ctrl_g:表示为快捷键<Ctrl+G>指定一条命令。
ctrl_l:表示为快捷键<Ctrl+L>指定一条命令。
ctrl_o:表示为快捷键<Ctrl+O>指定一条命令。
ctrl_t:表示为快捷键<Ctrl+T>指定一条命令。
ctrl_u:表示为快捷键<Ctrl+U>指定一条命令。
command:快捷键关联的命令行。
通过快捷键用户可以简便、快捷的操作设备,使用display hotkey命令可以查看设备支持的所有快捷键及其含义。
# 指定命令display tcp statistics的快捷键为<Ctrl+T>。
[Sysname] hotkey ctrl_t display tcp statistics
粉丝:219人 关注:0人
您好,没有这个的快捷键
