WX2520X-LI以后都不支持WA4320i-ACN了吗
2022-08-11提问
  • 1收藏,252浏览
换了新的ac控制器WX2520X-LI,ap列表没找到WA4320I-ACN,是不再支持了吗?是暂时未支持,还是以后都不会支持呢?目前公司还有很多WA4320i-ACN。WiFi5 866m也不算太落后吧?
粉丝:5人 关注:4人
如果升级新版本都不支持的话,那就是以后都不支持了
粉丝:143人 关注:1人
不在这里的就是不支持了,
WA4320i-ACN这是V5的AP,控制器是V7的
1.4 配套FIT AP列表
表3 配套FIT AP列表(国内款型
AP型号
AP-mode
文件名
是否打包
备注
H3C WA2610H
WA2610H
wa4300s.ipe
H3C WA2610H-LI
WA2610H-LI
H3C WA4320-ACN-SI
WA4320-ACN-SI
H3C WA4320H-SI
WA4320H-SI
H3C WA4320i-X-R
WA4320i-X-R
wa4300.ipe
H3C WA4320i-X
WA4320i-X
H3C WT1010-QU
WT1010-QU
wt1010.ipe
H3C WT1024-X
WT1024-X
wt1024x.ipe
H3C WT1024-X-HI
WT1024-X-HI
H3C WT1024-X-EI
WT1024-X-EI
H3C WT2024-U
WT2024-U
wt2024u.ipe
H3C WTU430
WTU430
wa4300s.ipe
H3C WTU410H
WTU410H
wa4300s.ipe
H3C WTU430H
WTU430H
wa4300h.ipe
H3C SIC-AP320
SIC-AP320
H3C WA5320-D
WA5320-D
H3C WA5320H-EPON
WA5320H-EPON
H3C WTU430H-IOT
WTU430H-IOT
H3C WTU430-EI
WTU430-EI
H3C WTU430-IOT
WTU430-IOT
H3C WTU430-HI
WTU430-HI
H3C WA4320H
WA4320H
H3C WA4320E
WA4320E
H3C WA5320H-LI
WA5320H-LI
H3C WTU430H-LI
WTU430H-LI
H3C WA4320-H20
WA4320-H20
wa5300.ipe
H3C WA5320E
WA5320E
H3C WA5320
WA5320
H3C WA5320H
WA5320H
H3C WA5320H-SI
WA5320H-SI
H3C WA5530
WA5530
H3C WA5320i
WA5320i
H3C WA5320-C
WA5320-C
H3C WA5320-C-EI
WA5320-C-EI
H3C WA5530X
WA5530X
H3C WA5530-SI
WA5530-SI
H3C WA5530E
WA5530E
H3C WA5320-TI
WA5320-TI
H3C WA5520-T
WA5520-T
H3C WA5340
WA5340
H3C WA5530i
WA5530i
H3C WA5530-LI
WA5530-LI
H3C WA5320S-E
WA5320S-E
H3C WA5530S
WA5530S
H3C WA5320i-LI
WA5320i-LI
H3C WA5320X-LI
WA5320X-LI
H3C WA5320XS-LI
WA5320XS-LI
H3C WA5320-C-IOT
WA5320-C-IOT
H3C UAP300
UAP300
H3C UAP380
UAP380
H3C UAP300-SI
UAP300-SI
H3C WA5320X
WA5320X
H3C WA5320X-L
WA5320X-L
H3C WA5320-SI
WA5320-SI
H3C WA5320X-SI
WA5320X-SI
H3C WA5320X-E
WA5320X-E
H3C WA5630X
WA5630X
H3C WA5322
WA5322
H3C WAK522
WAK522
H3C WAK532
WAK532
H3C WAK522H
WAK522H
H3C WAK522X
WAK522X
H3C WT1024-Q
WT1024-Q
wt1024q.ipe
H3C WT1024-X-Q
WT1024-X-Q
H3C WT1024-X-QH
WT1024-X-QH
H3C WA6330
WA6330
wa6300.ipe
H3C WA6320
WA6320
H3C WA6322
WA6322
H3C WA6322H-LI
WA6322H-LI
H3C WA6320H
WA6320H
H3C WA6320H-XEPON
WA6320H-XEPON
H3C WA6320H-LI
WA6320H-LI
H3C WA6330-LI
WA6330-LI
H3C WA6338-LI
WA6338-LI
H3C WA6320-C
WA6320-C
H3C WA6320-D
WA6320-D
H3C WA6320S-E
WA6320S-E
H3C WA6320S-C
WA6320S-C
H3C WA6320-SI
WA6320-SI
H3C WTU630
WTU630
H3C WTU630H
WTU630H
H3C WTU632H-IOT
WTU632H-IOT
H3C WA6338
WA6338
H3C WA6322H
WA6322H
H3C WA6320H-HI
WA6320H-HI
wa6500a.ipe
H3C WTU630-IOT
WTU630-IOT
H3C WA6522-C
WA6522-C
H3C WA6520-C
WA6520-C
H3C WA6522
WA6522
H3C WA6520XS-LI
WA6520XS-LI
H3C WA6520H
WA6520H
H3C WA6528
WA6528
wa6500.ipe
H3C WA6620
WA6620
wa6600.ipe
H3C WA6620X
WA6620X
H3C WA6620X-LI
WA6620X-LI
H3C WA6620XE-LI
WA6620XE-LI
H3C WA6622
WA6622
H3C WA6628
WA6628
H3C WA6628E-T
WA6628E-T
H3C WA6628XM
WA6628XM
H3C WA6628X
WA6628X
H3C WA6636
WA6636
H3C WA6638i
WA6638i
H3C WA6638
WA6638
H3C WA6630X
WA6630X
H3C WT1024-LI-Q
WT1024-LI-Q
wt1024liq.ipe
H3C WA6322H-HI
WA6322H-HI
wa6300a.ipe
H3C WA6338-HI
WA6338-HI
H3C WA6320-HI
WA6320-HI
H3C WA6320-SI-H20
WA6320-SI-H20
H3C WA6526
WA6526
wa6500a.ipe
H3C WA6526E
WA6526E
H3C WA6530
WA6530
H3C WA6530-LI
WA6530-LI
H3C WA6526H
WA6526H
H3C WA6520-HI
WA6520-HI
H3C WA6520H-EGPON
WA6520H-EGPON
H3C WA6522H-HI
WA6522H-HI
H3C WA6520
WA6520
H3C WA6520S-C
WA6520S-C
H3C WA6520S-E
WA6520S-E
H3C WA6522H-LI
WA6522H-LI
H3C WA6528i
WA6528i
wa6500b.ipe
H3C CPE5100
CPE5100
cpe5100.ipe
但我之前的AC控制器WX2510H也是V7的,也支持啊
yeguixiong 发表时间:2022-08-11
回复yeguixiong:
2510H里面有这个瘦AP的版本:http://www.h3c.com/cn/d_202208/1662954_30005_40.htm#_Toc109982875 这款AP支持V5和V7
叫我靓仔 发表时间:2022-08-12
sunny 八段
粉丝:9人 关注:0人
查看了最新版本,是不支持的
