msr2600-10用户名被锁死,权限只能访问不能修改,怎么才能恢复出场设置
  • 0收藏,1118浏览
sinaoa 零段
msr2600-10用户名被锁死,权限只能访问不能修改,怎么才能恢复出场设置?
另外:机器上面自带reset这个键是干嘛用的?
粉丝:15人 关注:2人
如果是console登录那就好办了,直接Ctrl+B,跳过当前配置;
如果是远程登录,估计你也操作不了,可以试一下:
<H3C>reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:y
Configuration file in flash: is being cleared.
Please wait ...
MainBoard:
Configuration file is cleared.
<H3C>reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:n
那个键是自曝用的!
