安装ipe软件包显示内存不够,只能通过boot页面进入,想在此页面删除无用文件
(0)
你好,boot删文件的话:
1、在boot扩展菜单首页选择输入File Control 对应的编号进入文件控制项(通过文件控制子菜单可以实现显示文件、设置文件类型、删除文件等操作)):
键入<Ctrl+B>系统进入BootWare扩展段主菜单。
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9):4 -----------这里
2、输入 Delete File对应的编号
===============================<File CONTROL>===============================
|Note:the operating device is cfa0 |
|<1> Display All File(s) |
|<2> Set Image File type |
|<3> Set Bin File type |
|<4> Set Configuration File type |
|<5> Delete File |
|<0> Exit To Main Menu |
Enter your choice(0-5):5 --这里
3、输入要删除的文件对应的序号就行:
|NO. Size(B) Time Type Name |
|1 956 Jan/21/2019 17:59:34 N/A cfa0:/ifindex.dat |
|2 24671 Mar/28/2018 09:08:56 N/A cfa0:/wdydiudie.cfg |
|3 735 Mar/28/2018 09:18:22 N/A cfa0:/hostkey |
|0 Exit |
Enter file No.: 2 --这里
输入文件编号选择待删除的文件,这里以删除编号为2的文件为例,键入数字2,终端显示信息如下:
The file you selected is sda0:/test.cfg,Delete it? [Y/N]
键入<Y>,如果终端显示如下提示信息,则表明文件删除成功:
Deleting.....Done!
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
