问题: 我这边的一个 VLAN 需要接入 超过 254 个无线终端,10个 AP由同一个 AC管理。于是我昨天把原来的VLAN VLAN 60 删除了,把 70 的掩码 由24改为 23,修改后的配置如下,今天的所有VLAN网络异常卡顿,常用的百度、京东甚至打不开,求解,我的
version 5.20, Release 5142P02
sysname ds_F100
clock timezone UTC add 00:00:00
l2tp enable
undo voice vlan mac-address 00e0-bb00-0000
interzone policy default by-priority
ip pool 1 172.18.10.2 172.18.10.254
domain default enable system
dns resolve
dns proxy enable
telnet server enable
qos carl 5 destination-ip-address subnet 172.18.5.0 24 per-address
qos carl 6 destination-ip-address subnet 172.18.6.0 24 per-address
qos carl 7 destination-ip-address subnet 172.18.7.0 24 per-address
qos carl 8 destination-ip-address subnet 172.18.8.0 24 per-address
qos carl 12 destination-ip-address subnet 172.18.12.0 24 per-address
qos carl 13 destination-ip-address subnet 172.18.13.0 24 per-address
qos carl 20 destination-ip-address range 172.18.5.209 to 172.18.5.210 per-address
qos carl 21 destination-ip-address range 172.18.5.211 to 172.18.5.212 per-address
qos carl 22 destination-ip-address range 172.18.5.213 to 172.18.5.254 per-address
qos carl 51 destination-ip-address range 172.18.5.2 to 172.18.5.206 per-address
qos carl 52 destination-ip-address range 172.18.5.207 to 172.18.5.208 per-address
qos carl 103 destination-ip-address range 172.18.5.2 to 172.18.5.103 per-address
qos carl 104 destination-ip-address range 172.18.5.104 to 172.18.5.105
qos carl 106 destination-ip-address range 172.18.5.106 to 172.18.5.206 per-address
port-security enable
undo alg dns
undo alg rtsp
undo alg h323
undo alg sip
undo alg sqlnet
undo alg ils
undo alg nbt
undo alg msn
undo alg qq
undo alg tftp
undo alg sccp
undo alg gtp
session synchronization enable
password-recovery enable
acl number 2000 match-order auto
rule 2 permit source 172.18.4.0 0.0.0.255
rule 3 permit source 172.18.5.0 0.0.0.255
rule 4 permit source 172.18.6.0 0.0.0.255
rule 5 permit source 172.18.7.0 0.0.0.255
rule 6 permit source 172.18.8.0 0.0.0.255
rule 7 permit source 172.18.11.0 0.0.0.255
rule 8 permit source 172.18.12.0 0.0.0.255
rule 9 permit source 172.18.13.0 0.0.0.255
rule 10 permit source 172.18.14.0 0.0.0.255
rule 11 permit source 172.18.3.0 0.0.0.255
rule 15 permit source 172.18.18.0 0.0.0.255
vlan 1
pki domain datastory
ca identifier CA Server
certificate request from ca
certificate request entity datastory
pki domain datastoryca
certificate request from ra
root-certificate fingerprint sha1 4DC243
pki domain default
crl check disable
qos policy ceshi003
dhcp server ip-pool vlan120
network 172.18.12.0 mask 255.255.255.0
gateway-list 172.18.12.1
dns-list 192.168.1.2
expired day 0 hour 4
dhcp server ip-pool vlan130
network 172.18.13.0 mask 255.255.255.0
gateway-list 172.18.13.1
expired day 0 hour 3
dhcp server ip-pool vlan180
network 172.18.18.0 mask 255.255.255.0
gateway-list 172.18.18.1
expired day 0 hour 1
dhcp server ip-pool vlan50
network 172.18.5.0 mask 255.255.255.0
gateway-list 172.18.5.1
dhcp server ip-pool vlan70
network 172.18.6.0 mask 255.255.254.0
gateway-list 172.18.7.1
expired day 0 hour 1 minute 30
dhcp server ip-pool vlan80
network 172.18.8.0 mask 255.255.255.0
gateway-list 172.18.8.1
policy-based-route 2000 permit node 10
if-match acl 2000
apply ip-address next-hop 192.168.1.3
user-group system
group-attribute allow-guest
local-user admin
password ci
authorization-attribute level 3
service-type telnet
service-type web
local-user u8user
password cipher $
service-type ppp
local-user vpnuser
password cipher $
service-type ppp
stp max-hops 30
stp bpdu-protection
stp enable
ssl server-policy access-policy
pki-domain datastory
cwmp
undo cwmp enable
interface NULL0
interface Vlan-interface1
ip policy-based-route 2000
interface GigabitEthernet0/1
port link-mode route
nat outbound 2000
ip address 192.168.1.3 255.255.255.0
qos car inbound carl 13 cir 30000 cbs 64000 ebs 0 green pass red discard
qos car inbound carl 14 cir 10000 cbs 64000 ebs 0 green pass red discard
qos car inbound carl 52 cir 20000 cbs 64000 ebs 0 green pass red discard
qos car inbound carl 8 cir 60000 cbs 64000 ebs 0 green pass red discard
qos car inbound carl 103 cir 10000 cbs 625000 ebs 0 green pass red discard
qos car inbound carl 104 cir 40000 cbs 2500000 ebs 0 green pass red discard
qos car inbound carl 106 cir 10000 cbs 625000 ebs 0 green pass red discard
qos car inbound carl 21 cir 40000 cbs 2500000 ebs 0 green pass red discard
qos car inbound carl 6 cir 40000 cbs 3750000 ebs 0 green pass red discard
qos car inbound carl 12 cir 40000 cbs 625000 ebs 0 green pass red discard
interface GigabitEthernet0/2
ip address XXXXXXXXXXX
interface GigabitEthernet0/3
interface GigabitEthernet0/3.1
vlan-type dot1q vid 140
ip address 172.18.14.1 255.255.255.0
interface GigabitEthernet0/4
interface GigabitEthernet0/4.3
vlan-type dot1q vid 50
ip address 172.18.5.1 255.255.255.0
interface GigabitEthernet0/4.5
vlan-type dot1q vid 70
ip address 172.18.7.1 255.255.254.0
interface GigabitEthernet0/4.6
vlan-type dot1q vid 80
ip address 172.18.8.1 255.255.255.0
interface GigabitEthernet0/4.8
vlan-type dot1q vid 120
ip address 172.18.12.1 255.255.255.0
interface GigabitEthernet0/4.9
vlan-type dot1q vid 130
ip address 172.18.13.1 255.255.255.0
interface GigabitEthernet0/4.15
vlan-type dot1q vid 180
ip address 172.18.18.1 255.255.255.0
vd Root id 1
zone name Management id 0
priority 100
import interface GigabitEthernet0/0
zone name Local id 1
priority 100
zone name Trust id 2
priority 85
import interface GigabitEthernet0/3
import interface GigabitEthernet0/3.1
import interface GigabitEthernet0/4
import interface GigabitEthernet0/4.3
import interface GigabitEthernet0/4.5
import interface GigabitEthernet0/4.6
import interface GigabitEthernet0/4.8
import interface GigabitEthernet0/4.9
import interface GigabitEthernet0/4.15
import interface Virtual-Template0
zone name DMZ id 3
priority 50
zone name Untrust id 4
priority 5
import interface GigabitEthernet0/1
import interface GigabitEthernet0/2
switchto vd Root
object service wannacry01
description 阻止比特币病毒
service tcp destination-port 445
object service wannacry02
service tcp destination-port 135
object service wannacry03
service tcp destination-port 137
object service wannacry04
service tcp destination-port 139
ip virtual-reassembly
zone name DMZ id 3
interzone source Trust destination Trust
rule 0 permit logging
source-ip any_address
destination-ip any_address
service any_service
rule enable
interzone source Untrust destination Trust
rule 2 deny
service wannacry01
service wannacry02
service wannacry03
service wannacry04
rule enable
service any_service
rule enable
ssl-vpn server-policy access-policy
ssl-vpn enable
ip route-static 0.0.0.0 0.0.0.0 192.168.1.2
dhcp enable
load xml-configuration
load tr069-configuration
user-interface con 0
user-interface vty 0 4
authentication-mode scheme
return
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
CPU 1% ,内存 29% ,温度 47 度,没有满负载的吧,之前都好好的,就是昨天我把 VLAN60删除了,把VLAN70的掩码由 24改为 23后,原来V少部分的 VLAN 60 的打印机、台式机都连接到 VLAN 70上。今天中午开始,就很卡了,全公司的台式机、笔记本都上网很慢,网页经常打不开。首先想请教一下,我这样设置的VLAN 70 ,得到的500个IP ,有没有问题
