mobaxterm每次重启总是恢复默认配置。没办法保存连接设置
2022-11-07提问
  • 0收藏,529浏览
查看日志,是 MobaXterm.ini变成只读权限了,修改权限后正常了
[11:47.28.920] Detecting IniSettings
[11:47.28.920] An existing INI file has been detected in "d:\Users\HYS\Documents\MobaXterm\MobaXterm.ini".
[11:47.28.920] MobaXterm will use this path for INI file.
[11:47.28.920] MobaXterm will take its configuration from file "d:\Users\HYS\Documents\MobaXterm\MobaXterm.ini".
[11:47.28.920] WARNING: SELECTED INI FILE SEEMS TO BE READ-ONLY!
[11:47.28.920] --> IniSettings= d:\Users\HYS\Documents\MobaXterm\MobaXterm.ini
[11:47.28.920]
[11:47.28.921]
[11:47.28.921] We are using the "New" SSH engine
[11:47.28.921]
这个相当于重新开项目,不会给你自动保存的
粉丝:101人 关注:4人
在会话里可以保存
