S7506E
2017-08-17提问
  • 1收藏,2435浏览
下面这份配置是6503上的 现在要把这份配置腾到新设备7506E上,acl是可以写进去的 ,但是接口下的配置写不了,请问一下,需要怎么操作呢?
 注:两个acl报文过滤都同时写在接口里面的
 pinterface GigabitEthernet1/0/7
 description toGuangBoJiFang<172.20.80.105>
 duplex full
 speed 1000
 port link-type trunk
 port trunk permit vlan all
 port trunk pvid vlan 200
 qosacket-filter inbound ip-group 3050 rule 57 system-index 412
 packet-filter inbound ip-group 3050 rule 58 system-index 413
 packet-filter inbound ip-group 3051 rule 0 system-index 532
 packet-filter inbound ip-group 3051 rule 1 system-index 533
 packet-filter inbound ip-group 3051 rule 2 system-index 534
 packet-filter inbound ip-group 3051 rule 3 system-index 535
acl number 3050
 rule 0 deny tcp source-port eq 3127
 rule 1 deny tcp source-port eq 1025
 rule 2 deny tcp source-port eq 5554
 rule 3 deny tcp source-port eq 9995
 rule 4 deny udp source-port eq 9995
 rule 5 deny tcp source-port eq 9996
 rule 6 deny udp source-port eq 9996
 rule 7 deny tcp source-port eq 1068
 rule 8 deny tcp source-port eq 135
 rule 9 deny tcp source-port eq 136
 rule 10 deny tcp source-port eq 137
 rule 11 deny tcp source-port eq 138
 rule 12 deny tcp source-port eq 139
 rule 13 deny udp source-port eq 135
 rule 14 deny udp source-port eq 136
 rule 15 deny udp source-port eq netbios-ns
 rule 16 deny udp source-port eq netbios-dgm
 rule 17 deny udp source-port eq netbios-ssn
 rule 18 deny tcp source-port eq 593
 rule 19 deny tcp source-port eq 4444
 rule 20 deny tcp source-port eq 5800
 rule 21 deny tcp source-port eq 5900
 rule 22 deny tcp source-port eq 8998
 rule 23 deny tcp source-port eq 445
 rule 24 deny udp source-port eq 445
 rule 25 deny tcp source-port eq 446
 rule 26 deny udp source-port eq 446
 rule 27 deny tcp source-port eq 1434
 rule 28 deny udp source-port eq 1434
 rule 29 deny tcp destination-port eq 3127
 rule 30 deny tcp destination-port eq 1025
 rule 31 deny tcp destination-port eq 5554
 rule 32 deny tcp destination-port eq 9995
 rule 33 deny udp destination-port eq 9995
 rule 34 deny tcp destination-port eq 9996
 rule 35 deny udp destination-port eq 9996
 rule 36 deny tcp destination-port eq 1068
 rule 37 deny tcp destination-port eq 135
 rule 38 deny tcp destination-port eq 136
 rule 39 deny tcp destination-port eq 137
 rule 40 deny tcp destination-port eq 138
 rule 41 deny tcp destination-port eq 139
 rule 42 deny udp destination-port eq 135
 rule 43 deny udp destination-port eq 136
 rule 44 deny udp destination-port eq netbios-ns
 rule 45 deny udp destination-port eq netbios-dgm
 rule 46 deny udp destination-port eq netbios-ssn
 rule 47 deny tcp destination-port eq 593
 rule 48 deny tcp destination-port eq 4444
 rule 49 deny tcp destination-port eq 5800
 rule 50 deny tcp destination-port eq 5900
 rule 51 deny tcp destination-port eq 8998
 rule 52 deny tcp destination-port eq 445
 rule 53 deny udp destination-port eq 445
 rule 54 deny tcp destination-port eq 446
 rule 55 deny udp destination-port eq 446
 rule 56 deny tcp destination-port eq 1434
 rule 57 deny udp destination-port eq 1434
 rule 58 permit ip
acl number 3051
 rule 0 deny ip destination 222.186.189.144 0
 rule 1 deny ip destination 222.186.189.145 0
 rule 2 deny ip destination 125.89.73.70 0
 rule 3 deny ip destination 125.89.73.74 0
 rule 4 deny ip destination 220.181.24.100 0
 rule 5 deny ip destination 61.188.87.235 0
 rule 6 deny ip destination 220.181.24.75 0
 rule 7 deny ip destination 54.251.107.25 0
 duplex full
 speed 1000
 qos
 packet-filter inbound ip-group 3050 rule 0 system-index 355
 packet-filter inbound ip-group 3050 rule 1 system-index 356
 packet-filter inbound ip-group 3050 rule 2 system-index 357
 packet-filter inbound ip-group 3050 rule 3 system-index 358
 packet-filter inbound ip-group 3050 rule 4 system-index 359
 packet-filter inbound ip-group 3050 rule 5 system-index 360
 packet-filter inbound ip-group 3050 rule 6 system-index 361
 packet-filter inbound ip-group 3050 rule 7 system-index 362
 packet-filter inbound ip-group 3050 rule 8 system-index 363
 packet-filter inbound ip-group 3050 rule 9 system-index 364
 packet-filter inbound ip-group 3050 rule 10 system-index 365
 packet-filter inbound ip-group 3050 rule 11 system-index 366
 packet-filter inbound ip-group 3050 rule 12 system-index 367
 packet-filter inbound ip-group 3050 rule 13 system-index 368
 packet-filter inbound ip-group 3050 rule 14 system-index 369
 packet-filter inbound ip-group 3050 rule 15 system-index 370
 packet-filter inbound ip-group 3050 rule 16 system-index 371
 packet-filter inbound ip-group 3050 rule 17 system-index 372
 packet-filter inbound ip-group 3050 rule 18 system-index 373
 packet-filter inbound ip-group 3050 rule 19 system-index 374
 packet-filter inbound ip-group 3050 rule 20 system-index 375
 packet-filter inbound ip-group 3050 rule 21 system-index 376
 packet-filter inbound ip-group 3050 rule 22 system-index 377
 packet-filter inbound ip-group 3050 rule 23 system-index 378
 packet-filter inbound ip-group 3050 rule 24 system-index 379
 packet-filter inbound ip-group 3050 rule 25 system-index 380
 packet-filter inbound ip-group 3050 rule 26 system-index 381
 packet-filter inbound ip-group 3050 rule 27 system-index 382
 packet-filter inbound ip-group 3050 rule 28 system-index 383
 packet-filter inbound ip-group 3050 rule 29 system-index 384
 packet-filter inbound ip-group 3050 rule 30 system-index 385
 packet-filter inbound ip-group 3050 rule 31 system-index 386
 packet-filter inbound ip-group 3050 rule 32 system-index 387
 packet-filter inbound ip-group 3050 rule 33 system-index 388
 packet-filter inbound ip-group 3050 rule 34 system-index 389
 packet-filter inbound ip-group 3050 rule 35 system-index 390
 packet-filter inbound ip-group 3050 rule 36 system-index 391
 packet-filter inbound ip-group 3050 rule 37 system-index 392
 packet-filter inbound ip-group 3050 rule 38 system-index 393
 packet-filter inbound ip-group 3050 rule 39 system-index 394
 packet-filter inbound ip-group 3050 rule 40 system-index 395
 packet-filter inbound ip-group 3050 rule 41 system-index 396
 packet-filter inbound ip-group 3050 rule 42 system-index 397
 packet-filter inbound ip-group 3050 rule 43 system-index 398
 packet-filter inbound ip-group 3050 rule 44 system-index 399
 packet-filter inbound ip-group 3050 rule 45 system-index 400
 packet-filter inbound ip-group 3050 rule 46 system-index 401
 packet-filter inbound ip-group 3050 rule 47 system-index 402
 packet-filter inbound ip-group 3050 rule 48 system-index 403
 packet-filter inbound ip-group 3050 rule 49 system-index 404
 packet-filter inbound ip-group 3050 rule 50 system-index 405
 packet-filter inbound ip-group 3050 rule 51 system-index 406
 packet-filter inbound ip-group 3050 rule 52 system-index 407
 packet-filter inbound ip-group 3050 rule 53 system-index 408
 packet-filter inbound ip-group 3050 rule 54 system-index 409
 packet-filter inbound ip-group 3050 rule 55 system-index 410
 packet-filter inbound ip-group 3050 rule 56 system-index 411
 packet-filter inbound ip-group 3050 rule 57 system-index 412
 packet-filter inbound ip-group 3051 rule 4 system-index 536
 packet-filter inbound ip-group 3051 rule 5 system-index 537
 packet-filter inbound ip-group 3051 rule 6 system-index 538
 packet-filter inbound ip-group 3051 rule 7 system-index 539
Kaiser 八段
粉丝:31人 关注:35人
新的设备接口下只需要引用ACL即可。不需要再配置ACL条目了
好的 谢谢 能举个列子吗?
zhiliao_28455 发表时间:2017-08-17
