核心交换机 7503 LLDP
2022-12-02提问
  • 0收藏,620浏览
%Dec 2 10:47:19:454 2022 HZJCY-WORK-HEXIN-IRF LLDP/6/LLDP_CREATE_NEIGHBOR: -MDC=1-Chassis=2-Slot=2; Nearest bridge agent neighbor created on port Ten-GigabitEthernet2/2/0/26 (IfIndex 1966), neighbor's chassis ID is 4857-02cd-931e, port ID is 4857-02cd-931e. %Dec 2 10:49:21:019 2022 HZJCY-WORK-HEXIN-IRF LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -MDC=1-Chassis=2-Slot=2; Nearest bridge agent neighbor aged out on port Ten-GigabitEthernet2/2/0/26 (IfIndex 1966), neighbor's chassis ID is 4857-02cd-931e, port ID is 4857-02cd-931e. %Dec 2 10:49:25:385 2022 HZJCY-WORK-HEXIN-IRF LLDP/6/LLDP_CREATE_NEIGHBOR: -MDC=1-Chassis=2-Slot=2; Nearest bridge agent neighbor created on port Ten-GigabitEthernet2/2/0/26 (IfIndex 1966), neighbor's chassis ID is 4857-02cd-931e, port ID is 4857-02cd-931e. %Dec 2 10:51:11:423 2022 HZJCY-WORK-HEXIN-IRF LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -MDC=1-Chassis=1-Slot=2; Nearest bridge agent neighbor aged out on port Ten-GigabitEthernet1/2/0/25 (IfIndex 219), neighbor's chassis ID is 4857-02cd-9333, port ID is 4857-02cd-9333. %Dec 2 10:51:19:283 2022 HZJCY-WORK-HEXIN-IRF LLDP/6/LLDP_CREATE_NEIGHBOR: -MDC=1-Chassis=1-Slot=2; Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/2/0/25 (IfIndex 219), neighbor's chassis ID is 4857-02cd-9333, port ID is 4857-02cd-9333. %Dec 2 10:26:27:019 2022 HZJCY-WORK-HEXIN-IRF LLDP/5/LLDP_NEIGHBOR_AGE_OUT: -MDC=1-Chassis=2-Slot=2; Nearest bridge agent neighbor aged out on port Ten-GigabitEthernet2/2/0/25 (IfIndex 1965), neighbor's chassis ID is 341e-6b4b-695c, port ID is 341e-6b4b-695c.
6 个回答
粉丝:7人 关注:1人
问题是啥都没看出来
看这个描述就是lldp邻居老化了吧,看看接口目前都正常UP吗
小L_Engineer 发表时间:2022-12-02
zhiliao_AE37Rk 知了小白
我第一次上来提问。。。。 都不知道排版是这么混乱的...,再次发起又说已经发起相应的提问,又删不掉。我真的。。。
粉丝:4人 关注:0人
复制进word
再粘贴到这里就会排版了
或者截l
粉丝:143人 关注:1人
可以直接发截图试试
zhiliao_AE37Rk 知了小白
pc端可以来这里提问的吗?手机端操作比较麻烦。
粉丝:180人 关注:8人
就是建立邻居和邻居老化的日志
