S3600进不去怎么办
2017-08-18提问
  • 1收藏,1621浏览
 BOOT MENU
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Reserved
9. Set switch startup mode
0. Reboot
Ctrl+F: Format File System
Ctrl+P: Skip Super Password
Ctrl+R: Download application to SDRAM and Run
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+C: Display Copyright
Enter your choice(0-9):
JuneQ 六段
粉丝:15人 关注:4人
3点进去看看有没有版本文件,如果有就重新指定一下为下次启动的版本,如果没有就重新上传一个试试
3点进去后还是弹出这个界面
zhiliao_73548 发表时间:2017-08-18
那应该是没有文件吧
JuneQ 发表时间:2017-08-18
qic99me 知了小白
也可以选择7尝试跳过交换机配置。
