s5130s-28TP
2023-03-08提问
  • 0收藏,622浏览
s5130s-28TP支持三层交换协议吗?能配置三层网络交换协议吗?s5130s-28TP和s5130s- 28P有什么区别?
粉丝:94人 关注:0人
型号
交换容量
包转发率(整机)
业务端口描述
外形尺寸(宽×深×高)(单位:mm)
POE
管理端口
S5130S-10P-EI
336Gbps/3.36Tbps
24Mpps/102Mpps
8个10/100/1000Base-T自适应以太网端口,2个千兆SFP口
266×161 ×43.6
1个Console口
S5130S-12TP-EI
336Gbps/3.36Tbps
27Mpps/102Mpps
8个10/100/1000Base-T自适应以太网端口,4个千兆SFP口(其中两个combo口)
266×161 ×43.6
S5130S-20P-EI
336Gbps/3.36Tbps
39Mpps/102Mpps
16个10/100/1000Base-T自适应以太网端口,4个千兆SFP口
330×230 ×43.6
S5130S-28P-EI
336Gbps/3.36Tbps
51Mpps/126Mpps
24个10/100/1000Base-T自适应以太网端口,4个千兆SFP口
440×160×43.6
S5130S-28S-EI
336Gbps/3.36Tbps
108Mpps/126Mpps
24个10/100/1000Base-T自适应以太网端口,4个万兆SFP+口
440×160×43.6
S5130S-28TP-EI
336Gbps/3.36Tbps
51Mpps/126Mpps
24个10/100/1000Base-T自适应以太网端口,4个千兆SFP口(2combo口)
440×160×43.6
S5130S-52P-EI
432Gbps/4.32Tbps
87Mpps/166Mpps
48个10/100/1000Base-T自适应以太网端口,4个千兆SFP口
440×230×43.6
S5130S-52S-EI
432Gbps/4.32Tbps
144Mpps/166Mpps
48个10/100/1000Base-T自适应以太网端口,4个万兆SFP+口
440×230×43.6
S5130S-52TP-EI
432Gbps/4.32Tbps
87Mpps/166Mpps
48个10/100/1000Base-T自适应以太网端口,4个千兆SFP口(2combo口)
440×230×43.6
S5130S-52ST-EI
432Gbps/4.32Tbps
144Mpps/166Mpps
48个10/100/1000BASE-T自适应以太网端口,2个10G BASE-X SFP+端口,2个1/2.5/5/10G BASE-T电口
440×260×43.6
S5130S-28ST-EI
336Gbps/3.36Tbps
108Mpps/126Mpps
24个10/100/1000BASE-T自适应以太网端口,2个10G BASE-X SFP+端口,2个1/2.5/5/10G BASE-T电口
440×160×43.6
S5130S-28F-EI
336Gbps/3.36Tbps
108Mpps/126Mpps
24个100/1000 SFP光口(其中有8个combo口),4个10G/1G BASE-X SFP+端口
440×360 ×43.6
S5130S-52F-EI
432Gbps/4.32Tbps
144Mpps/166Mpps
48个千兆SFP光口(其中有2个combo口),4个万兆SFP+光口
440×360 ×43.6
S5130S-28PS-EI
336Gbps/3.36Tbps
108Mpps/126Mpps
24个10/100/1000BASE-T电口,支持8个SFP Combo口,4个10G BASE-X SFP+端口
440×360×43.6
S5130S-20P-PWR-EI
336Gbps/3.36Tbps
39Mpps/102Mpps
330×230 ×43.6
PWR与HPWR款型均支持802.3af/PoE、802.3at/PoE+供电标准,单端口最大支持30W;UPWR款型支持802.3bt/POE++供电标准,向下兼容802.3af、802.3at
S5130S-10P-HPWR-EI
336Gbps/3.36Tbps
24Mpps/102Mpps
330×230 ×43.6
S5130S-12TP-HPWR-EI
336Gbps/3.36Tbps
27Mpps/102Mpps
330×230 ×43.6
S5130S-28P-PWR-EI
336Gbps/3.36Tbps
51Mpps/126Mpps
440×260 ×43.6
S5130S-28S-PWR-EI
336Gbps/3.36Tbps
108Mpps/126Mpps
440×260 ×43.6
S5130S-28P-HPWR-EI
336Gbps/3.36Tbps
51Mpps/126Mpps
24个10/100/1000Base-T自适应以太网端口,4个千兆SFP口(combo口)
440×260 ×43.6
S5130S-28S-HPWR-EI
336Gbps/3.36Tbps
108Mpps/126Mpps
24个10/100/1000Base-T自适应以太网端口(其中有4个combo口),4个万兆SFP+口
440×260 ×43.6
S5130S-52P-PWR-EI
432Gbps/4.32Tbps
87Mpps/166Mpps
440×400 ×43.6
S5130S-52S-PWR-EI
432Gbps/4.32Tbps
144Mpps/166Mpps
440×400 ×43.6
S5130S-28P-HPWR-EI-AC
336Gbps/3.36Tbps
51Mpps/126Mpps
440×260 ×43.6
S5130S-28S-HPWR-EI-AC
336Gbps/3.36Tbps
108Mpps/126Mpps
440×260 ×43.6
S5130S-52P-PWR-EI-AC
432Gbps/4.32Tbps
87Mpps/166Mpps
440×400 ×43.6
S5130S-52S-PWR-EI-AC
432Gbps/4.32Tbps
144Mpps/166Mpps
440×400 ×43.6
S5130S-28S-HPWR-EI-Q
336Gbps/3.36Tbps
108Mpps/126Mpps
440×422×43.6
S5130S-16S-UPWR-EI-Q
336Gbps/3.36Tbps
63Mpps/126Mpps
12个10/100/1000Base-T PoE++端口,2个10/100/1000Base-T端口,2个万兆SFP+口
300×260 ×43.6
S5130S-28S-UPWR-EI-Q
336Gbps/3.36Tbps
108Mpps/126Mpps
8个10/100/1000Base-T PoE++端口, 16个10/100/1000Base-T PoE+端口
4个万兆SFP+口
440×420×43.6
S5130S-52ST-PWR-EI
432Gbps/4.32Tbps
144Mpps/166Mpps
48个10/100/1000Base-T自适应以太网端口,2个10G BASE-X SFP+端口,2个1/2.5/5/10G BASE-T电口
440×320 ×43.6
S5130S-28ST-PWR-EI
336Gbps/3.36Tbps
108Mpps/126Mpps
24个10/100/1000Base-T自适应以太网端口,2个10G BASE-X SFP+端口,2个1/2.5/5/10G BASE-T电口
440×320 ×43.6
S5130S-16S-PWR-EI
336Gbps/3.36Tbps
63Mpps/126Mpps
12个10/100/1000Base-T PoE+端口,2个10/100/1000Base-T端口,2个万兆SFP+口
300×260 ×43.6
S5130S-10MS-UPWR-EI
336Gbps/3.36Tbps
75Mpps/126Mpps
8个100M/1G/2.5G BASE-T(UPoE)端口,2个万兆SFP+口
300×260 ×43.6
S5130S-28P-EI-M
336Gbps/3.36Tbps
51Mpps/126Mpps
24个10/100/1000BASE-T自适应以太网端口,4个千兆SFP端口
440×160×43.6
S5130S-52P-EI-M
432Gbps/4.32Tbps
87Mpps/166Mpps
48个10/100/1000BASE-T自适应以太网端口,4个千兆SFP端口
440×230×43.6
S5130S-28S-EI-M
336Gbps/3.36Tbps
108Mpps/126Mpps
24个10/100/1000BASE-T自适应以太网端口,4个万兆SFP+端口
440×160×43.6
S5130S-52S-EI-M
432Gbps/4.32Tbps
144Mpps/166Mpps
48个10/100/1000BASE-T自适应以太网端口,4个万兆SFP+端口
440×230×43.6
S5130S-28S-EI-DP
336Gbps/3.36Tbps
108Mpps/126Mpps
440×260×43.6
型号
重量
输入电压
整机功耗
温度
湿度
S5130S-10P-EI
≤1.5kg
AC:额定电压范围:100V~240V A.C,50/60Hz
AC
MIX:7W
MAX:12W
工作环境温度:-5℃~45℃
工作环境相对湿度(非凝露):5%~95%
S5130S-12TP-EI
≤1.5kg
AC
MIX:8W
MAX:15W
S5130S-20P-EI
≤3kg
AC
MIX:9W
MAX:19W
S5130S-28P-EI
≤2.5kg
AC
MIX:9W
MAX:23W
S5130S-28S-EI
≤2.5kg
AC
MIX:10W
MAX:24W
S5130S-28TP-EI
≤2.5kg
AC
MIX:10W
MAX:24W
S5130S-52P-EI
≤3.5kg
AC
MIX:18W
MAX:41W
S5130S-52S-EI
≤3.5kg
AC
MIX:19W
MAX:44W
S5130S-52TP-EI
≤3.5kg
AC
MIX:20W
MAX:42W
S5130S-52ST-EI
≤3.5kg
AC
MIX:22W
MAX:53W
S5130S-28ST-EI
≤2.5kg
AC
MIX:14W
MAX:36W
S5130S-28F-EI
≤6kg
DC:输入额定电压范围 -48V~-60V DC
AC
MIX:15W
MAX:55W
DC
MIX:18W
MAX:57W
S5130S-52F-EI
≤6.5kg
AC
MIX:26W
MAX:95W
DC
MIX:27W
MAX:95W
S5130S-28PS-EI
≤5.5kg
AC
MIN:12W
MAX:31W
DC
MIX:11W
MAX:26W
S5130S-20P-PWR-EI
≤3kg
AC
MIN:18W
MAX:210W(POE为170W)
S5130S-10P-HPWR-EI
≤3kg
AC
MIN:13W
MAX:153W(POE为125W)
S5130S-12TP-HPWR-EI
≤3kg
AC
MIN:14W
MAX:156W(POE为125W)
S5130S-28P-PWR-EI
≤4kg
AC
MIN:19W
MAX:230W(POE为170W)
S5130S-28S-PWR-EI
≤4kg
AC
MIN:20W
MAX:235W(POE为170W)
S5130S-28P-HPWR-EI
≤4.5kg
DC:输入额定电压范围 -54V~-57V DC
AC
MIN:23W
MAX:446W(POE为370W)
DC
MIN:16W
MAX:790W(POE为740W)
S5130S-28S-HPWR-EI
≤4.5kg
AC
MIN:24W
MAX:451W(POE为370W)
DC
MIN:17W
MAX:793W(POE为740W)
S5130S-52P-PWR-EI
≤6kg
AC
MIN:36W
MAX:467W(POE为370W)
DC
MIN:26W
MAX:807W(POE为740W)
S5130S-52S-PWR-EI
≤6kg
AC
MIN:37W
MAX:478W(POE为370W)
DC
MIN:29W
MAX:825W(POE为740W)
≤4.5kg
AC
MIN:15W
MAX:443w(POE为370W)
≤4.5kg
AC
MIN:16W
MAX:445w(POE为370W)
≤6kg
AC
MIN:36W
MAX:467w(POE为370W)
≤6kg
AC
MIN:36W
MAX:467w(POE为370W)
≤6kg
AC
MIN:12W
MAX:400W(POE为370W)
≤3.5kg
AC
MIN:12W
MAX:402W(POE为370W)
≤6kg
AC
MIN:14W
MAX:405W(POE为370W)
S5130S-52ST-PWR-EI
≤6kg
AC
MIN:32W
MAX:AC:470W(PoE为370W)
S5130S-28ST-PWR-EI
≤4.5kg
AC
MIN:20W
MAX:AC:450W(PoE为370W)
S5130S-16S-PWR-EI
≤2.5kg
AC:
MIN:14W
MAX:157W(POE为125W)
S5130S-10MS-UPWR-EI
3.5kg
AC
MIN:23W
MAX:447W(POE为370W)
DC
MIN:18W
MAX:794.2W(POE为740W)
S5130S-28P-EI-M
≤2.5kg
AC
MIN:9W
MAX:23W
S5130S-52P-EI-M
≤3.5kg
AC
MIN:18W
MAX:41W
S5130S-28S-EI-M
≤2.5kg
AC
MIN:10W
MAX:24W
S5130S-52S-EI-M
≤3.5kg
AC
MIN:19W
MAX:44W
S5130S-28S-EI-DP
≤3.5kg
AC
MIN:
单:11W
双:15W
MAX:
单:25W
双:26W
业务特性
特性
特性描述
链路聚合
支持GE端口聚合
支持10GE端口聚合
支持静态聚合
支持动态聚合
支持跨设备聚合
流量控制
支持802.3x流控及半双工背压流控
Jumbo Frame
支持
MAC地址表
支持黑洞MAC地址
支持设置端口MAC地址学习最大个数
SDN/Openflow
支持OpenFlow 1.3标准
支持多控制器(EQUAL模式、主备模式)
支持多表流水线
支持Group table
支持Meter
VLAN
支持802.1Q VLAN
支持基于端口的VLAN
支持QinQ、灵活QinQ
支持Voice VLAN
支持协议VLAN
支持MAC VLAN
ARP
支持免费ARP
支持动态ARP检测(DAI)
支持ARP限速
ND
支持ND
支持ND Snooping
VLAN虚接口
支持
DHCP
支持DHCP/DHCPv6 Client
支持DHCP/DHCPv6 Snooping
支持 DHCP/DHCPv6 Relay
支持DHCP/DHCPv6 Server
支持DHCP/DHCPv6 Option82
DNS
支持静态域名解析
支持动态域名解析客户端
支持IPv4和IPv6地址
单播路由
支持IPv4/IPv6双栈
支持IPv4/IPv6静态路由
支持RIPv1/RIPv2/RIPng,OSPF v1/v2/v3
组播
支持IGMP Snooping
支持MLD Snooping
支持组播VLAN
广播/组播/单播风暴抑制
支持基于端口速率百分比的风暴抑制
支持基于PPS的风暴抑制
支持基于bps的风暴抑制
二层环网协议
支持STP/RSTP/MSTP协议
支持STP Root Protection
支持BPDU Protection
支持G.8032以太网环保护协议ERPS,切换时间≤50ms,可兼容其他支持该协议的产品
支持RRPP
SmartLink
支持
QoS/ACL
支持802.1p/DSCP优先级标记
支持包过滤功能
支持SP/WRR/SP+WRR队列调度
支持基于端口的限速
支持基于流的重定向
支持时间段
镜像
支持端口镜像
支持远程镜像
安全特性
支持用户分级管理和口令保护
支持AAA认证
支持Radius认证
支持HWTACACS
支持SSH2.0
支持端口隔离
支持 802.1X
支持端口安全
支持MAC地址认证
支持IP Source Guard
支持SAVI
支持防DOS攻击
支持防ARP攻击
支持防ICMP攻击
支持HTTPs
支持PKI(Public Key Infrastructure,公钥基础设施)
支持EAD
802.1X
支持802.1X认证
支持基于端口的认证和基于MAC的认证
支持Guest VLAN
支持TRUNK端口认证
支持基于802.1x动态下发QoS/ACL/VLAN
加载与升级
支持XModem协议实现加载升级
支持FTP(File Transfer Protocol)加载升级
支持TFTP(Trivial File Transfer Protocol)加载升级
管理
支持命令行接口(CLI)配置
支持Telnet远程配置
支持通过Console口配置
支持SNMP(EImple Network Management Protocol)
支持RMON(Remote Monitoring)告警、事件、历史记录
支持iMC网管系统
支持WEB网管
支持系统日志
支持分级告警
支持Python脚本管理运维
支持IRF堆叠,最多可支持9台设备
支持NTP
支持电源、风扇、温度告警
维护
支持调试信息输出
支持Ping、Tracert
支持Telnet远程维护
支持NQA
支持802.1ag
支持802.3ah
支持DLDP
支持虚拟电缆检测(Virtual Cable Test)
粉丝:115人 关注:8人
有部分三层功能的
