S5500 上联BR2005路由器访问外网
2023-03-13提问
  • 0收藏,650浏览
问题:
客户端vlan2(192.168.2.0/24)和vlan3(192.168.3.0/24)无法通过路由器访问互联网,路由跟踪到了网关就下不去了。
vlan2 网关:192.168.2.100, vlan3 网关:192.168.3.100, 默认vlan1网关:192.168.31.200。
两个VLAN客户端可以相互ping通,客户端也能ping通各自网关。
不知道是不是要在路由器上设置路由?具体怎么设置,请各位大拿指点,谢谢。
网络拓扑:
网络环境描述:
客户端有两个网段,通过DHCP从交换机S5500获取IP,S5500上联BR2005路由器,通过路由器访问外网。
S5500通过端口23连接路由器,端口23使用的是默认vlan1, vlan1 IP:192.168.31.200/24
交换机上设置了静态路由,下一跳是路由器IP:192.168.31.1,从交换机上可以访问互联网,但是客户端2个网段都无法访问互联网。
交换机配置如下:
 # version 5.20, Release 2221P15 # sysname H3C # clock timezone CST add 08:00:00 # dhcp relay server-group 1 ip 192.168.31.1 # irf mac-address persistent timer irf auto-update enable undo irf link-delay # domain default enable system # ipv6 # ip ttl-expires enable ip unreachables enable # password-recovery enable # vlan 1 # vlan 2 to 3 # domain system access-limit disable state active idle-cut disable self-service-url disable # dhcp server ip-pool vlan2 network 192.168.2.0 mask 255.255.255.0 network ip range 192.168.2.11 192.168.2.100 gateway-list 192.168.2.100 dns-list 202.101.172.35 # dhcp server ip-pool vlan3 network 192.168.3.0 mask 255.255.255.0 network ip range 192.168.3.11 192.168.3.200 gateway-list 192.168.3.100 dns-list 202.101.172.35 # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$eMop8zbuiYOT0B2cOI15GByE+kh+j2hDCGm5vg== authorization-attribute level 3 service-type telnet service-type web # interface NULL0 # interface Vlan-interface1 ip address 192.168.31.200 255.255.255.0 dns server 202.101.172.35 # interface Vlan-interface2 ip address 192.168.2.100 255.255.255.0 dns server 202.101.172.35 # interface Vlan-interface3 ip address 192.168.3.100 255.255.255.0 # interface GigabitEthernet1/0/1 port link-mode bridge port access vlan 2 # interface GigabitEthernet1/0/2 port link-mode bridge port access vlan 2 # interface GigabitEthernet1/0/3 port link-mode bridge port access vlan 2 # interface GigabitEthernet1/0/4 port link-mode bridge port access vlan 2 # interface GigabitEthernet1/0/5 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/6 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/7 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/8 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/9 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/10 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/11 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/12 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/13 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/14 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/15 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/16 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/17 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/18 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/19 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/20 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/21 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/22 port link-mode bridge port access vlan 3 # interface GigabitEthernet1/0/23 port link-mode bridge # interface GigabitEthernet1/0/24 port link-mode bridge port link-type trunk port trunk permit vlan all # interface GigabitEthernet1/0/25 port link-mode bridge shutdown # interface GigabitEthernet1/0/26 port link-mode bridge shutdown # interface GigabitEthernet1/0/27 port link-mode bridge shutdown # interface GigabitEthernet1/0/28 port link-mode bridge shutdown # interface Ten-GigabitEthernet1/1/1 port link-mode bridge # interface Ten-GigabitEthernet1/1/2 port link-mode bridge # dhcp-snooping # ip route-static 0.0.0.0 0.0.0.0 192.168.31.1 # snmp-agent snmp-agent local-engineid 800063A2035CDD705B6C73 snmp-agent sys-info version v3 # dhcp server forbidden-ip 192.168.2.100 dhcp server forbidden-ip 192.168.3.100 # dhcp enable # ssh server enable # ip https enable # load xml-configuration # load tr069-configuration # user-interface aux 0 authentication-mode password set authentication password cipher $c$3$KUQd6SfIgoAJvr+Xt2hAATv06DHTkNJVO5bSOw== user-interface vty 0 4 user privilege level 3 set authentication password cipher $c$3$8s+nd++U3n2C6zq66t7/mpVk94XksZhFDCGjNQ== user-interface vty 5 15 # return
粉丝:179人 关注:8人
需要写路由的
请问要怎么写呢?
zhiliao_DPWQ8V 发表时间:2023-03-13
网关在交换机上吧,交换机和路由器写路由
zhiliao_sEUyB 发表时间:2023-03-13
回复zhiliao_sEUyB:
谢谢,客户端网关是交换机VLAN接口地址,交换机上写了默认路由到路由器地址,但是这样客户端访问不了外网,是不是路由器上还要配置路由?
路由器要回指路由,
粉丝:94人 关注:0人
检查路由 nat配置
请问是在路由器上配置一条NAT路由吗
zhiliao_DPWQ8V 知了小白
这软件排版怎么这么奇葩,明明是一条记录一行,发出来都连在一起了。
