S5500-52C-EI 有什么办法解决arp报文泛洪
2017-08-27提问
  • 1收藏,2955浏览
粉丝:226人 关注:0人
出现ARP报文泛洪,有什么解决办法没?
现象是:
%Aug 24 02:03:43:865 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/36 with IP address 0.0.0.0 (Total 24 packets dropped).
%Aug 24 02:03:44:866 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/36 with IP address 0.0.0.0 (Total 25 packets dropped).
%Aug 24 02:03:45:865 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/36 with IP address 169.254.181.28 (Total 26 packets dropped).
%Aug 24 02:03:48:375 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/36 with IP address 0.0.0.0 (Total 27 packets dropped).
%Aug 24 02:03:49:366 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/36 with IP address 0.0.0.0 (Total 28 packets dropped).
%Aug 24 02:03:50:366 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/36 with IP address 0.0.0.0 (Total 29 packets dropped).
%Aug 24 02:03:59:261 2017 SZFW-JR-4#-1X-H3CS5500-EI RDS/6/RDS_SUCC: -Slot=1; -IfName=GigabitEthernet1/0/36-VlanId=67-MACAddr=98:EE:CB:42:97:EA-IPAddr=10.18.67.7-IPv6Addr=N/A-UserName=sajj087@system; User got online successfully.
%Aug 24 02:04:00:367 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/36 with IP address 0.0.0.0 (Total 30 packets dropped).
%Aug 24 02:04:01:365 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/36 with IP address 0.0.0.0 (Total 31 packets dropped).
%Aug 24 02:04:02:366 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/36 with IP address 0.0.0.0 (Total 32 packets dropped).
%Aug 24 02:04:28:271 2017 SZFW-JR-4#-1X-H3CS5500-EI RDS/6/RDS_SUCC: -IfName=GigabitEthernet2/0/21-VlanId=67-MACAddr=98:EE:CB:3E:9E:36-IPAddr=10.18.67.17-IPv6Addr=N/A-UserName=sajj036@system; User got online successfully.
%Aug 24 02:04:29:585 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: Detected an inspection occurred on interface GigabitEthernet2/0/21 with IP address 0.0.0.0 (Total 2255 packets dropped).
%Aug 24 02:04:30:601 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: Detected an inspection occurred on interface GigabitEthernet2/0/21 with IP address 0.0.0.0 (Total 2256 packets dropped).
%Aug 24 02:04:31:581 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: Detected an inspection occurred on interface GigabitEthernet2/0/21 with IP address 0.0.0.0 (Total 2257 packets dropped).
%Aug 24 02:05:36:992 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/4 with IP address 0.0.0.0 (Total 38 packets dropped).
%Aug 24 02:05:37:991 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/4 with IP address 0.0.0.0 (Total 39 packets dropped).
%Aug 24 02:05:38:990 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/4 with IP address 0.0.0.0 (Total 40 packets dropped).
%Aug 24 02:05:39:990 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/4 with IP address 169.254.161.241 (Total 41 packets dropped).
%Aug 24 02:05:49:082 2017 SZFW-JR-4#-1X-H3CS5500-EI RDS/6/RDS_SUCC: -Slot=1; -IfName=GigabitEthernet1/0/4-VlanId=67-MACAddr=3C:97:0E:D5:D5:B9-IPAddr=N/A-IPv6Addr=N/A-UserName=sajj072@system; User got online successfully.
%Aug 24 02:05:50:489 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/4 with IP address 0.0.0.0 (Total 42 packets dropped).
%Aug 24 02:05:51:489 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/4 with IP address 0.0.0.0 (Total 43 packets dropped).
%Aug 24 02:05:52:532 2017 SZFW-JR-4#-1X-H3CS5500-EI ARP/5/ARP_INSPECTION: -Slot=1; Detected an inspection occurred on interface GigabitEthernet1/0/4 with IP address 0.0.0.0 (Total 44 packets dropped).
粉丝:32人 关注:5人
规避的方法是接入配置ARP限速以及其他ARP防护,当然从根因排查的话还是得解决网络中是否存在arp攻击以及TC刷新了网络中的ARP信息。
Cookie 七段
粉丝:6人 关注:3人
如果是电脑中毒,可以尝试在接入交换机上配置端口绑定。
如果是网络本身有环路,建议开启生成树再观察观察
