H3C S5130-28S-EI 如何查看数据流量是否超限
2017-09-01提问
  • 1收藏,2323浏览
如题,
因设备没有到货 ,现用有一台5130做核心,连平台服务器,云存储。现在问题是实况可以看,录像卡顿,从5130到存储服务器不丢包,电脑连接5130ping存储服务器丢包严重。其他平台网络正常。前段300路摄像回传4M码流存储,存储录像是正常,就是回访看不了。现在就想问问,如何从交换机入手定位问题。求助各位大神。
Kaiser 八段
粉丝:34人 关注:35人
在5130上做流统定位,同时看接口有无pause.帧
感谢,能不能帮我看下下面的信息
完败的小熊熊 发表时间:2017-09-01
<HXSB-XPFJ-S5130>dis int GigabitEthernet 1/0/1 GigabitEthernet1/0/1 Current state: UP Line protocol state: UP IP packet frame type: Ethernet II, hardware address: 487a-da82-8b02 Description: GigabitEthernet1/0/1 Interface Bandwidth: 1000000 kbps Loopback is not set Media type is twisted pair Port hardware type is 1000_BASE_T 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 9216 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 2103 MDI type: Automdix Port link-type: Access Tagged VLANs: None Untagged VLANs: 2103 Port priority: 0 Last clearing of counters: Never Peak input rate: 1374320 bytes/sec, at 2013-02-02 20:50:34 Peak output rate: 123364859 bytes/sec, at 2013-02-02 11:26:05 Last 300 second input: 15538 packets/sec 1237279 bytes/sec 1% Last 300 second output: 82738 packets/sec 123333724 bytes/sec 99% Input (total): 919060285 packets, 72437167561 bytes 919060285 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input (normal): 919060285 packets, - bytes 919060285 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, 0 throttles 0 CRC, 0 frame, - overruns, 0 aborts - ignored, - parity errors Output (total): 5540844399 packets, 8259583925843 bytes 5540684683 unicasts, 1725 broadcasts, 157991 multicasts, 0 pauses Output (normal): 5540844399 packets, - bytes 5540684683 unicasts, 1725 broadcasts, 157991 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, - no carrier
out都99%了
