H3C MSR 900路由器CPU占用率100%
  • 1收藏,6598浏览
公司路由器带办公电脑40台,手机等无线设备30台,只要下载或上传东西,路由器的CPU占用率就达到90%以上,延迟高,死机;
配置如下:
 version 5.20, Release 2311
 sysname H3C
 clock timezone Beijing add 08:00:00
 l2tp enable
 firewall enable
 firewall fragments-inspect
 domain default enable system
 dns resolve
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 qos carl 1 destination-ip-address range 186.88.1.20 to 186.88.1.230 per-address
 qos carl 2 source-ip-address range 186.88.1.20 to 186.88.1.230 per-address
 port-security enable
 ip user-based-sharing enable
acl number 4999
 rule 0 deny source-mac 54a0-5086-9528 ffff-ffff-ffff
 rule 2 permit
vlan 1
domain system
 authentication ppp local
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
traffic classifier urllimit-1 operator or
traffic behavior behaviorforfilter
 filter deny
interface Dialer10
 nat outbound
 nat outbound 3000
 nat server 1 protocol tcp global current-interface 3389 inside 186.88.1.227 3389
 nat server 15 protocol tcp global current-interface ftp inside 186.88.1.227 ftp
 nat server 17 protocol tcp global current-interface 90 inside 186.88.1.95 90
 nat server 18 protocol tcp global current-interface 1433 inside 186.88.1.227 1433
 nat server 19 protocol tcp global current-interface 6666 inside 186.88.1.123 6666
 nat server 20 protocol tcp global current-interface 41362 inside 186.88.1.123 41362
 nat server 22 protocol tcp global current-interface 18168 inside 186.88.1.147 18168
 nat server 12 protocol tcp global current-interface 10010 inside 186.88.1.25 3389
 nat server 21 protocol tcp global current-interface 10095 inside 186.88.1.95 3389
 nat server 16 protocol tcp global current-interface gopher inside 186.88.1.227 gopher
 nat server 23 protocol tcp global current-interface 443 inside 186.88.1.227 8443
 nat server 2 protocol tcp global current-interface 18605 inside 186.88.1.8 3389
 nat server 3 protocol tcp global current-interface 18608 inside 186.88.1.88 3389
 nat server 6 protocol tcp global current-interface 4200 inside 186.88.1.36 4200
 firewall packet-filter 4999 outbound
 link-protocol ppp
 ppp chap user 310127704
 ppp chap password cipher $c$3$kXarX0AZklkvuIJGVpvGBuiJSrkJdanpSc1JBg==
 ppp pap local-user 310127704 password cipher $c$3$tTfIBS3NDa691ZITeWqoUukp1eA+ms6vf7ljJw==
 ppp ipcp dns admit-any
 ppp ipcp dns request
 mtu 1492
 ip address ppp-negotiate
 tcp mss 1024
 dialer user username
 dialer-group 10
 dialer bundle 10
 qos car inbound carl 1 cir 5000 cbs 500000 ebs 0 green pass red discard
 qos car outbound carl 2 cir 5000 cbs 64000 ebs 0 green pass red discard
TIM截图20170902101455
跪求各位大神给看看 问题出在哪里
1个路由器,2台交换机
DrTF是代表转发进程,VIDL是代表空闲进程,建议联系400,问下转发进程占用过高的原因,看看有没有优化的方法
粉丝:17人 关注:0人
一般DrTF高是设备觉得数据流量太大,如果说要优化,就建议让更少的流量上到此设备,根据经验来说,建议将有线和无线的网关做到下面的交换机上去,在交换机上就终结vlan,如果本身你的网络就是这样的,那么可以考虑给路由器升级一个版本观察,因为目前你的版本是2012年的,太老啦。
请问一下,版本固件在哪下载?
因特耐特 发表时间:2017-09-02
回复因特耐特:
http://www.h3c.com/cn/Service/Software_Download/Router/Catalog/MSR/MSR_900%5B920%5D/201612/966937_30005_40.htm#_Toc470096990 请使用账号yx800密码01230123进行下载
吃巧克力会死 发表时间:2017-09-02
已经升级固件,但是还是不行,CPU一直在40%以上,如果使用下载或上传软件,CPU立即100%跑死
大神,你看下我发的接口流量信息,是不是异常,该如何排查解决
因特耐特 知了小白
Vlan-interface1 current state: UP
Description: Vlan-interface1 Interface
The Maximum Transmit Unit is 1500
Internet Address is 186.88.1.254/24 Primary
IP Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 7425-8a75-b8fb
IPv6 Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 7425-8a75-b8fb
Output queue : (Urgent queuing : Size/Length/Discards)  0/100/0
Output queue : (Protocol queuing : Size/Length/Discards)  0/500/0
Output queue : (FIFO queuing : Size/Length/Discards)  0/75/0
 Last clearing of counters:  Never
    Last 300 seconds input rate: 694417 bytes/sec, 5555336 bits/sec, 1546 packets/sec
    Last 300 seconds output rate: 1034615 bytes/sec, 8276920 bits/sec, 1803 packets/sec
    44122997 packets input, 35788454244 bytes, 81212 drops
    43449054 packets output, 17296694776 bytes, 0 drops
粉丝:12人 关注:7人
基于用户负载分担需要关闭快转,是不是把内网口快转关掉了? 如果关掉快转,设备CPU利用率很容易飙高
ip fast-forwarding [ inbound | outbound ]
大神你好,如果关闭基于用户负载分担 功能,是否需要开启内网口快转呢,我是小白,不太懂
因特耐特 发表时间:2017-09-05
回复因特耐特:
建议都开启,否则CPU负担太大。
战五渣 发表时间:2017-09-05
