msr50-06 配置及WEB管理页面不能使用问题
2017-09-07提问
  • 1收藏,3166浏览
路由器的配置:(端口0/2可用)
[H3C]dis cur
 sysname H3C
 local-server nas-ip 127.0.0.1 key huawei
 dialer-rule 1 ip permit
radius scheme system
domain system
local-user admin
 password simple admin
 service-type telnet
 level 3
dhcp server ip-pool 1
 network 192.168.0.0 mask 255.255.255.0
 gateway-list 192.168.0.1
 dns-list 114.114.114.114
acl number 2000
 rule 0 permit source 192.168.0.0 0.0.0.255
 rule 1 deny
interface Aux0
 async mode flow
interface Dialer1
 link-protocol ppp
 ppp chap user 918919664798
 ppp chap password simple 666888
 ppp pap local-user ***** password simple ******
 tcp mss 1024
 ip address ppp-negotiate
 dialer user ******
 dialer-group 1
 dialer bundle 1
 nat outbound 2000
interface GigabitEthernet0/0
 pppoe-client dial-bundle-number 1
interface GigabitEthernet0/1
interface GigabitEthernet0/2
 ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/3
interface NULL0
firewall zone local
 set priority 100
firewall zone trust
 set priority 85
firewall zone untrust
 set priority 5
firewall zone DMZ
 set priority 50
 dhcp server forbidden-ip 192.168.0.1 192.168.0.100
 ip route-static 0.0.0.0 0.0.0.0 Dialer 1 preference 60
user-interface con 0
user-interface aux 0
user-interface vty 0 4
return
粉丝:12人 关注:7人
之前正常吗?有升级过版本吗?
我看接口都没加安全域,这个都要加的,虽然不要配置策略放通啥的。
那可以帮忙指导下用指令模式配置成下面的模式吗?
zhiliao_77037 发表时间:2017-09-07 更多>>
这个设备拿过来恢复了设置,原来不清楚谁管理的了,所以版本不清楚有没有升级过。 <H3C>dis ver H3C Comware Software Comware software, Version 3.40, Release 6114 Copyright (c) 2004-2008 Hangzhou H3C Technologies Co., Ltd. All rights reserved. Without the owner's prior written consent, no decompiling nor reverse-engineering shall be allowed. H3C MSR50-06 uptime is 0 week, 0 day, 3 hours, 45 minutes Last reboot 2017/09/07 08:38:28 CPU type: Mips BCM1125H 800MHz 512M bytes DDR SDRAM Memory 16M bytes Flash Memory Pcb Version:4.0 Logic Version:1.0 BootROM Version:15.05 [SLOT 0] 1GBE (Hardware)4.0, (Driver)2.0, (Cpld)1.0 [SLOT 1] 1GBE (Hardware)4.0, (Driver)2.0, (Cpld)1.0 [SLOT 2] 1GBE (Hardware)2.0, (Driver)2.0, (Cpld)1.0 [SLOT 3] 1GBE (Hardware)2.0, (Driver)2.0, (Cpld)1.0 关于安全域什么的,没搞过这些,都是靠百度, 不太懂。现在就想把另外一个端口配成我想设置的形式用着,或者看有什么方式能开起来WEB配置。
编辑贴子的时候,问题描述没了,补充在下面
回复zhiliao_77037:
firewall zone trust add interface GigabitEthernet0/2 # firewall zone untrust add interface Dialer1
战五渣 发表时间:2017-09-07
谢谢回复,还麻烦请你看下补充的问题描述。
WEB页面打开后,提示的报错如下: HTTP/1.1 404 NOT FOUND! Check flash:/http.zip,please.
如果不能通过WEB方式登录,请按照下面的步骤进行排查: 1. 检查Flash中是否有“http.zip”文件;如果没有该文件,请使用命令:detach system来释放出“http.zip”文件; 2. 如果有“http.zip”文件,说明此文件是以前VRP程序里面的,请先删除该文件,再使用命令:detach system来释放出“http.zip”文件; 3. 如果通过FTP、TFTP方式进行升级后,那么需要先删除“http.zip”,再使用命令:detach system来释放出“http.zip”文件; 4. 如果在BootRom下进行升级,升级成功,则正常。
战五渣 发表时间:2017-09-07
1. flash中没有 http.zip 文件。2.执行detach system指令后,提示如下: <H3C>detach system % No http file! 3. 怎么可以找到完整升级包去升级?去官网好像下载不了。
设备里的文件只有3个: File Number File Size(bytes) File Name 1. 7470244 system 2. 151 private-data.txt 3. 1377 config.cfg 用户模式下dir ,system 文件的时间是2002年的,这么早固件应该没有做过升级吧,是不是那会还没有WEB管理的功能。 <H3C>dir Directory of flash:/ 1 -rw- 7470244 Oct 10 2002 10:10:10 system 2 -rw- 1377 Sep 07 2017 12:44:24 config.cfg
回复zhiliao_77037:
没有就没有了,现在这款设备不维护了,版本估计也没了。
战五渣 发表时间:2017-09-07
zhiliao_77037 知了小白
编辑过一次,问题描述没有了,补充如下:
下图是我想要设置的模式,但目前设备执行 vlan指令报错。另外打开 web管理页面报 缺少http.zip文件。
[H3C]vlan 1
 % Unrecognized command found at '^' position.
[H3C]interface vlan 1
 % Wrong parameter found at '^' position.
wt
想通过WEB来设置,或看如何能按上图的方式进行配置。
