目前MSR 登录web页面时,显示有什么办法恢复
设备配置为
<wangguan>
#Jan 1 00:02:34:063 2013 wangguan NETMAN/4/IP Address Changed:
Trap 1.3.6.1.4.1.25506.2.90.3.2.0.1<hh3cIpAddrChangeNotify>: Management interface IP address changed: IpAddressType is 1, IpAddress is 192.168.1.1, CustomBuildInfo is 000FE2, SerialNum is 210235A1A2M15B000016.
<wangguan>dis cu
version 5.20, Release 2516P11
sysname wangguan
domain default enable system
dns proxy enable
telnet server enable
dar p2p signature-file flash:/p2p_default.mtd
ndp enable
ntdp enable
cluster enable
port-security enable
password-recovery enable
ip user-based-sharing enable
vlan 1
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$40gC1cxf/wIJNa1ufFPJsjKAof+QP5aV
authorization-attribute level 3
service-type telnet
service-type web
cwmp
undo cwmp enable
interface Aux0
async mode flow
link-protocol ppp
interface Cellular0/0
async mode protocol
link-protocol ppp
tcp mss 1024
interface NULL0
interface GigabitEthernet0/0
port link-mode route
interface GigabitEthernet0/1
interface GigabitEthernet0/2
port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
duplex full
interface GigabitEthernet0/9
dhcp enable
nms primary monitor-interface GigabitEthernet0/0
load xml-configuration
load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
authentication-mode scheme
return
<wangguan>
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
还是显示功能函数错误
我是修改配置后出现的这种情况,可能是吧某些重要配置删除了 ,现在添加了HTTP服务开启,以及HTTPs。还是这种情况,请问有什么办法解决吗
