MSR 26-00
  • 0收藏,1261浏览
目前MSR 登录web页面时,显示有什么办法恢复
设备配置为
<wangguan>
#Jan  1 00:02:34:063 2013 wangguan NETMAN/4/IP Address Changed:
 Trap 1.3.6.1.4.1.25506.2.90.3.2.0.1<hh3cIpAddrChangeNotify>: Management interface IP address changed: IpAddressType is 1, IpAddress is 192.168.1.1, CustomBuildInfo is 000FE2, SerialNum is 210235A1A2M15B000016.
<wangguan>dis cu
 version 5.20, Release 2516P11
 sysname wangguan
 domain default enable system
 dns proxy enable
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 cluster enable
 port-security enable
 password-recovery enable
 ip user-based-sharing enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$40gC1cxf/wIJNa1ufFPJsjKAof+QP5aV
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
interface GigabitEthernet0/1
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
 duplex full
interface GigabitEthernet0/9
 dhcp enable
 nms primary monitor-interface GigabitEthernet0/0
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
<wangguan>
Guohao 九段
粉丝:23人 关注:1人
配置中并没有开启web服务,是使用中出现的web网管无法登陆吗,还是近期修改配置或重启后无法登陆的?
可开启web服务再试一下,ip http enable
还是显示功能函数错误
小白求帮忙 发表时间:2017-09-08
我是修改配置后出现的这种情况,可能是吧某些重要配置删除了 ,现在添加了HTTP服务开启,以及HTTPs。还是这种情况,请问有什么办法解决吗
