S5560-30C-EI,IRF2的一个端口显示DOWN
2017-09-08提问
  • 1收藏,1717浏览
S5560-30C-EI 两台做IRF2
[vxrail]display irf
MemberID    Role    Priority  CPU-Mac         Description
   1        Standby 1         00e0-fc0f-8c02  ---
 *+2        Master  1         00e0-fc0f-8c03  ---
 The bridge MAC of the IRF is: 600b-03a1-4fc7
 Auto upgrade                : yes
 Mac persistent              : 6 min
 Domain ID                   : 0
[vxrail]
[vxrail]display irf topology
                              Topology Info
               IRF-Port1                IRF-Port2
 MemberID    Link       neighbor      Link       neighbor    Belong To
 2           DIS        ---           UP         1           00e0-fc0f-8c03
 1           UP         2             DIS        ---         00e0-fc0f-8c03
[vxrail]
[vxrail]display irf link
Member 1
 IRF Port  Interface                             Status
 1         Ten-GigabitEthernet1/0/27             UP
           Ten-GigabitEthernet1/0/28             DOWN
 2         disable                               --
Member 2
 1         disable                               --
 2         Ten-GigabitEthernet2/0/27             UP
           Ten-GigabitEthernet2/0/28             DOWN
[vxrail]
[vxrail]
[vxrail]display irf configuration
 MemberID NewID    IRF-Port1                     IRF-Port2
 1        1        Ten-GigabitEthernet1/0/27     disable
 2        2        disable                       Ten-GigabitEthernet2/0/27
[vxrail]
[vxrail]
[vxrail]display mad verbose
Multi-active recovery state: No
Excluded ports (user-configured):
Excluded ports (system-configured):
MAD ARP disabled.
MAD ND disabled.
MAD LACP disabled.
MAD BFD enabled interface: Vlan-interface4000
  MAD status                 : Normal
  Member ID   MAD IP address       Neighbor   MAD status
  1           172.18.1.1/24        2          Normal
  2           172.18.1.2/24        1          Normal
请问
Member 1
这个down 是正常的吗
zhiliao_98130 知了小白
重新28口插拔一下就好了
是不是网线没有插好啊
-4811 九段
粉丝:28人 关注:1人
是28口没连光纤吧,只连了27口?
