出现这个是因为环路吗?怎么解决呢
%Sep 8 01:37:14:091 2017 SZFW-JR-4#-1X-H3CS5500-EI MSTP/6/MSTP_FORWARDING: -Slot=2; Instance 0's port GigabitEthernet2/0/23 has been set to forwarding state.
%Sep 8 01:37:14:091 2017 SZFW-JR-4#-1X-H3CS5500-EI MSTP/6/MSTP_DETECTED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/23 detected a topology change.
%Sep 8 01:37:14:879 2017 SZFW-JR-4#-1X-H3CS5500-EI RDS/6/RDS_SUCC: -Slot=2; -IfName=GigabitEthernet2/0/23-VlanId=67-MACAddr=F8:0F:41:14:E7:20-IPAddr=10.18.67.31-IPv6Addr=N/A-UserName=sajj066@system; User got online successfully.
%Sep 8 01:37:58:456 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/35 link status is DOWN.
%Sep 8 01:38:01:550 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/35 link status is UP.
%Sep 8 01:38:19:373 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/35 link status is DOWN.
%Sep 8 01:38:22:746 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/35 link status is UP.
%Sep 8 01:38:52:567 2017 SZFW-JR-4#-1X-H3CS5500-EI MSTP/6/MSTP_FORWARDING: Instance 0's port GigabitEthernet1/0/35 has been set to forwarding state.
%Sep 8 01:38:52:568 2017 SZFW-JR-4#-1X-H3CS5500-EI MSTP/6/MSTP_DETECTED_TC: Instance 0's port GigabitEthernet1/0/35 detected a topology change.
%Sep 8 01:39:49:994 2017 SZFW-JR-4#-1X-H3CS5500-EI RDS/6/RDS_SUCC: -Slot=2; -IfName=GigabitEthernet2/0/36-VlanId=67-MACAddr=3C:97:0E:D5:D5:BC-IPAddr=10.18.67.13-IPv6Addr=N/A-UserName=sajj108@system; User got online successfully.
%Sep 8 01:42:18:396 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet3/0/11 link status is DOWN.
%Sep 8 01:42:20:401 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet3/0/11 link status is UP.
%Sep 8 01:42:23:106 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet3/0/11 link status is DOWN.
%Sep 8 01:44:25:982 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/35 link status is DOWN.
%Sep 8 01:44:29:110 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/35 link status is UP.
%Sep 8 01:44:47:470 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/35 link status is DOWN.
%Sep 8 01:44:50:552 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet1/0/35 link status is UP.
%Sep 8 01:45:06:168 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet2/0/37 link status is DOWN.
%Sep 8 01:45:08:945 2017 SZFW-JR-4#-1X-H3CS5500-EI IFNET/3/LINK_UPDOWN: GigabitEthernet2/0/37 link status is UP.
%Sep 8 01:45:20:505 2017 SZFW-JR-4#-1X-H3CS5500-EI MSTP/6/MSTP_FORWARDING: Instance 0's port GigabitEthernet1/0/35 has been set to forwarding state.
%Sep 8 01:45:20:506 2017 SZFW-JR-4#-1X-H3CS5500-EI MSTP/6/MSTP_DETECTED_TC: Instance 0's port GigabitEthernet1/0/35 detected a topology change.
%Sep 8 01:45:38:352 2017 SZFW-JR-4#-1X-H3CS5500-EI MSTP/6/MSTP_FORWARDING: -Slot=2; Instance 0's port GigabitEthernet2/0/37 has been set to forwarding state.
%Sep 8 01:45:38:353 2017 SZFW-JR-4#-1X-H3CS5500-EI MSTP/6/MSTP_DETECTED_TC: -Slot=2; Instance 0's port GigabitEthernet2/0/37 detected a topology change.
(0)
不一定跟环路有关系吧,你这里面1/0/35、3/0/11、2/0/37这几个接口一直在频繁震荡,导致stp拓扑改变,看看为什么接口会震荡,如果是借终端的端口,可以将这些端口设置为边缘端口
(0)
边缘端口怎么设置呢?
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
