H3C S5820X-28C nqa+track静态路由不生效
2024-05-26提问
  • 0收藏,1739浏览
设备型号:H3C S5820X-28C
软件版本:s5800_5820x-cmw520-r1808p12
问题:NQA+Track绑定静态路由不生效
设备型号:H3C S5820X-28C
详细配置:
nqa entry admin test
 type icmp-echo
  destination ip 10.2.1.254
  frequency 100
  history-record enable
  next-hop 172.16.20.1
  reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
  source ip 172.16.20.2
track 1 nqa entry admin test reaction 1
 nqa schedule admin test start-time now lifetime forever
 ip route-static 0.0.0.0 0.0.0.0 172.16.20.1 track 1
 ip route-static 0.0.0.0 0.0.0.0 172.16.21.1 preference 80
查看track信息
display track all
Track ID: 1
  Status: Positive
  Duration: 0 days 0 hours 9 minutes 0 seconds
  Notification delay: Positive 0, Negative 0 (in seconds)
  Reference object:
    NQA entry: admin test
    Reaction: 1
display nqa result
  NQA entry (admin admin, tag test) test results:
    Destination IP address: 10.2.1.254
      Send operation times: 1              Receive response times: 1
      Min/Max/Average round trip time: 2/2/2
      Square-Sum of round trip time: 4
      Last succeeded probe time: 2000-08-07 22:15:14.1
    Extended results:
      Packet loss in test: 0%
      Failures due to timeout: 0
      Failures due to disconnect: 0
      Failures due to no connection: 0
      Failures due to sequence error: 0
      Failures due to internal error: 0
      Failures due to other errors: 0
      Packet(s) arrived late: 0
display nqa history
  NQA entry (admin admin, tag test) history record(s):
    Index      Response     Status           Time
    5932       3            Succeeded        2000-08-07 22:15:19.5
    5931       3            Succeeded        2000-08-07 22:15:19.4
    5930       3            Succeeded        2000-08-07 22:15:19.3
    5929       3            Succeeded        2000-08-07 22:15:19.2
    5928       2            Succeeded        2000-08-07 22:15:19.1
    5927       3            Succeeded        2000-08-07 22:15:19.0
    5926       2            Succeeded        2000-08-07 22:15:18.9
    5925       2            Succeeded        2000-08-07 22:15:18.8
各种信息都有,端口对端线路,静态路由不切换;请问知道什么原因吗?求解....
粉丝:4人 关注:0人
我们联动的是我们本地的路由,管不到对端,现在你这个track是po正常的呀,探测失败是negetive,才去联动
mqa现在都是探测成功的,你得探测是失败,track才能去联动,检测这条线路没问题,单跳多跳都行,联动的条件是您探测的目标地址不可达了之后,track才能联动路由,现在您是通的,看一下官网的案例,配置我看是没啥问题,理解问题
zhiliao_Lyfcmg 发表时间:2024-05-26 更多>>
你好,只监测对端地址也不行吗
zhiliao_mglaXh 发表时间:2024-05-26
如下组网可以使用那种方式呢,我要监测10.2.1.254这根线路
zhiliao_mglaXh 知了小白
现场这这种组网模式,是本地路由,但是监测对端地址,不通信不应该切换吗
