H3C MSR20-10告警日志查询
2017-09-18提问
  • 1收藏,4499浏览
%Sep 18 07:59:32:748 2017 cd_lttg_msr2010 PPPOEC/6/PPPOEC_LOG_FAIL_SERVER_ERR: PPPoE user failed to log on for no response was received from server.
%Sep 18 08:00:04:748 2017 cd_lttg_msr2010 PPPOEC/6/PPPOEC_LOG_FAIL_SERVER_ERR: PPPoE user failed to log on for no response was received from server.
%Sep 18 08:00:36:750 2017 cd_lttg_msr2010 PPPOEC/6/PPPOEC_LOG_FAIL_SERVER_ERR: PPPoE user failed to log on for no response was received from server.
%Sep 18 08:01:08:749 2017 cd_lttg_msr2010 PPPOEC/6/PPPOEC_LOG_FAIL_SERVER_ERR: PPPoE user failed to log on for no response was received from server.
%Sep 18 08:01:40:749 2017 cd_lttg_msr2010 PPPOEC/6/PPPOEC_LOG_FAIL_SERVER_ERR: PPPoE user failed to log on for no response was received from server.
%Sep 18 08:02:12:750 2017 cd_lttg_msr2010 PPPOEC/6/PPPOEC_LOG_FAIL_SERVER_ERR: PPPoE user failed to log on for no response was received from server.
%Sep 18 08:02:44:750 2017 cd_lttg_msr2010 PPPOEC/6/PPPOEC_LOG_FAIL_SERVER_ERR: PPPoE user failed to log on for no response was received from server.
请问这个告警是什么造成的,有没有办法确认是哪个端口造成的?现在设备运行正常,是不是拨号端口开启了服务造成的?如果是的话怎么排除这些告警?请知道的告诉下,谢谢了
你这台设备应该是pppoe client,一直在向外拨号,但是一直没有拨号成功,返回的信息是pppoe server无响应,看一下是那个接口配置pppoe client命令,如果不需要pppoe拨号,删除pppoe client就可以了
粉丝:2人 关注:0人
从日志看是pppoe服务器没有响应导致拨号失败,设备上有哪些关于拨号的配置?
有一个配置,我现在在确认,应该是一楼说的那种情况造成的
