丢包问题
2017-09-21提问
  • 1收藏,4735浏览
这是客户的一个监控核心交换机,华为S9700的。现在设备的延时达到了87S,丢包挺严重的。检查发现这三个端口有问题,然后拔掉后还是有丢包。
求帮忙:这几个端口可能是什么情况?为什么这几个端口关掉后还是有丢包情况?谢谢了
[KELJC_S9700M]dis int g 1/0/3
GigabitEthernet1/0/3 current state : DOWN
Line protocol current state : DOWN
Description:
Switch Port, Link-type : trunk(configured),
PVID :    1, TPID : 8100(Hex), The Maximum Frame Length is 9216
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 4cf9-5def-bb10
Last physical up time   : 2017-09-18 08:01:11
Last physical down time : 2017-09-21 05:06:14
Current system time: 2017-09-21 05:42:34
Port Mode: COMMON FIBER, Transceiver: 1000_BASE_LX_SFP
Speed : 1000,   Loopback: NONE
Duplex: FULL,   Negotiation: ENABLE
Mdi   : -,      Flow-control: DISABLE
Last 300 seconds input rate 0 bits/sec, 0 packets/sec
Last 300 seconds output rate 0 bits/sec, 0 packets/sec
Input peak rate 0 bits/sec, Record time: -
Output peak rate 0 bits/sec, Record time: -
Input:  19967590083 packets, 26276459831747 bytes
  Unicast:                19959068505,  Multicast:                     2575824
  Broadcast:                  4210347,  Jumbo:                               0
  Discard:                          0,  Pause:                               0
  Frames:                           0
  Total Error:                1735407
  CRC:                         861861,  Giants:                              0
  Jabbers:                          0,  Fragments:                         694
  Runts:                            0,  DropEvents:                          0
  Alignments:                       0,  Symbols:                        872852
  Ignoreds:                         0
Output:  2981743222 packets, 424172106794 bytes
  Unicast:                 2931583504,  Multicast:                    15390865
  Broadcast:                 34768853,  Jumbo:                               0
  Total Error:                      0
  Collisions:                       0,  ExcessiveCollisions:                 0
  Late Collisions:                  0,  Deferreds:                           0
  Buffers Purged:                   0
    Input bandwidth utilization threshold : 80.00%
    Output bandwidth utilization threshold: 80.00%
    Input bandwidth utilization  :    0%
    Output bandwidth utilization :    0%
[KELJC_S9700M]dis int g 2/0/1
GigabitEthernet2/0/1 current state : DOWN
Description:NVR
Switch Port, Link-type : access(configured),
PVID :  115, TPID : 8100(Hex), The Maximum Frame Length is 9216
Last physical up time   : 2017-09-15 10:24:11
Last physical down time : 2017-09-21 05:20:38
Current system time: 2017-09-21 05:43:23
Port Mode: COMMON COPPER
Mdi   : AUTO,   Flow-control: DISABLE
Input peak rate 518208152 bits/sec, Record time: 2017-09-13 04:23:21
Output peak rate 480089488 bits/sec, Record time: 2017-09-17 09:37:34
Input:  12395786546 packets, 12001313073493 bytes
  Unicast:                12394827043,  Multicast:                       27694
  Broadcast:                   931208,  Jumbo:                               0
  Frames:                           0
  Total Error:                    601
  CRC:                            393,  Giants:                              0
  Jabbers:                          3,  Fragments:                           0
  Alignments:                       0,  Symbols:                           205
  Ignoreds:                         0
Output:  11771886182 packets, 13920603716342 bytes
  Unicast:                11747212045,  Multicast:                     6738461
  Broadcast:                 17935676,  Jumbo:                               0
  Discard:                          4,  Pause:                               0
  Total Error:                      0
  Buffers Purged:                   0
[KELJC_S9700M]dis int g 2/0/10
GigabitEthernet2/0/10 current state : UP
Line protocol current state : UP
Description:
Last physical up time   : 2017-09-21 05:33:24
Last physical down time : 2017-09-21 05:33:20
Current system time: 2017-09-21 05:43:39
Last 300 seconds input rate 3824 bits/sec, 4 packets/sec
Last 300 seconds output rate 18344 bits/sec, 17 packets/sec
Input peak rate 1531544 bits/sec, Record time: 2017-09-17 09:12:41
Output peak rate 422428048 bits/sec, Record time: 2017-09-17 09:37:34
Input:  905826 packets, 104022000 bytes
  Unicast:                     887771,  Multicast:                         749
  Broadcast:                    17306,  Jumbo:                               0
  Frames:                           0
  Total Error:                      0
  CRC:                              0,  Giants:                              0
  Jabbers:                          0,  Fragments:                           0
  Alignments:                       0,  Symbols:                             0
  Ignoreds:                         0
Output:  6694987 packets, 7501824457 bytes
  Unicast:                    6277833,  Multicast:                      124331
  Broadcast:                   292823,  Jumbo:                               0
  Discard:                      27552,  Pause:                               0
  Total Error:                      0
  Buffers Purged:                   0
[KELJC_S9700M]dis int g 2/0/21
GigabitEthernet2/0/21 current state : UP
Description:
Last physical up time   : 2017-09-11 09:42:45
Last physical down time : 2017-09-11 09:42:07
Current system time: 2017-09-21 05:43:58
Last 300 seconds input rate 59496 bits/sec, 68 packets/sec
Last 300 seconds output rate 107968 bits/sec, 92 packets/sec
Input peak rate 655212008 bits/sec, Record time: 2017-09-11 09:47:41
Output peak rate 423147024 bits/sec, Record time: 2017-09-11 10:47:14
Input:  1063155247 packets, 1320952323256 bytes
  Unicast:                 1063078111,  Multicast:                       28317
  Broadcast:                    48819,  Jumbo:                               0
  Frames:                           0
  Total Error:                      0
  CRC:                              0,  Giants:                              0
  Ignoreds:                         0
Output:  1377865334 packets, 959035892117 bytes
  Unicast:                 1352167352,  Multicast:                     6878800
  Broadcast:                 18819182,  Jumbo:                               0
  Total Error:                      0
  Buffers Purged:                   0
    Input bandwidth utilization  : 0.01%
    Output bandwidth utilization : 0.01%
开启了STP没?开启了的话就检查一下有没有某一些链路不停UP/DOWN导致网络震荡
然后最好开启terminal monitor 和查看一下日志,有没有IP冲突的情况;监控网如果一些摄像头没有初始化的话,会有一个默认的IP地址,这种IP地址如果重复多了,也会导致丢包
粉丝:28人 关注:2人
华为交换机?
是的
原木琪彩 发表时间:2017-09-21
有点不明白,发现这三个端口有问题,拔掉了还是有问题,就不是这三个端口的事了,建议,按着连接的线路,点到点,点到核心,弱电井交换机口,摄像头,都ping 下,
