WA6520H-HI 电信闪讯 ppoe场景下 出现端口dhcp异常,换端口故障恢复
2024-12-04提问
  • 0收藏,189浏览
环境:
WA6520H-HI  -》  FS5300-48US  -》   S6520X-30QC -》  中兴 -》  电信bars
终端通过无线ap有线端口接入 ,6520做qinq  内部vlan2116   外部vlan 2022  其余设备vlan透传
故障现象:
出现个别终端获取不到ip地址,通过更换ap有线端口地址恢复故障,故障试查看mac地址已经到中兴交换机侧,电信端查看mac地址回显较慢,但mac地址已经到电线侧了。故障终端在有问题的端口故障依旧,更换端口后故障立马恢复,现场同环境下终端正常
 version 7.1.064, Release 2609P10
 sysname
 clock timezone Beijing add 08:00:00
 telnet server enable
 lldp global enable
 lldp hold-multiplier 8
vlan 1
vlan 503 to 504
vlan 1051
vlan 1071 to 1074
vlan 1076
vlan 1081
vlan 1085
vlan 2116
nqa template icmp apmgr-aptoac-icmp
 data-size 1500
 frequency 1000
 probe timeout 1000
 reaction trigger per-probe
interface NULL0
interface Vlan-interface1
 ip address dhcp-alloc
 ipv6 address dhcp-alloc
 port access vlan 2116
 port-isolate enable
 broadcast-suppression pps 100
 multicast-suppression pps 100
 port-isolate enable
 port-isolate enable
interface GigabitEthernet1/0/4
 port-isolate enable
interface GigabitEthernet1/0/5
 port-isolate enable
interface GigabitEthernet1/0/6
 port-isolate enable
interface GigabitEthernet1/0/7
 port-isolate enable
interface GigabitEthernet1/0/8
 port-isolate enable
interface GigabitEthernet1/0/9
 port-isolate enable
interface WLAN-Radio1/0/1
interface WLAN-Radio1/0/2
interface Smartrate-Ethernet1/0/1
 port link-type trunk
 port trunk permit vlan all
 scheduler logfile size 16
line class console
 user-role network-admin
line class vty
 user-role network-operator
line con 0
line vty 0 4
line vty 5 63
 undo gratuitous-arp-learning enable
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
return
粉丝:272人 关注:8人
是更换的那个端口 ,检查下相应端口的日志情况 协商情况
回复zhiliao_sEUyB:
配置都一样无差别,这个端口之前也是正常在使用的,偶发性出现故障
初本寻梦 发表时间:2024-12-04 更多>>
跟换ap侧端口,对应日志都无异常,mac地址表现也正常能到中兴侧交换机
回复初本寻梦:
检查下两个端口的配置差异
zhiliao_sEUyB 发表时间:2024-12-04
回复zhiliao_sEUyB:
