WS5820-28X-POE-WiNet 6361版本tftp备份异常
2025-01-05提问
  • 0收藏,1479浏览
H3C WS5820-28X-POE-WiNet交换机升级到最新版本tftp备份配置失败,升级前是对的应该是软件bug。交换机与tftp服务器通信正常升级版本前的6331版本是可以正常备份的
backup startup-configuration to 172.20.1.10
Backing up the main startup configuration file to 172.20.1.10...
Backup failed, TFTP error!
H3C Comware Software, Version 7.1.070, Release 6361
Copyright (c) 2004-2023 New H3C Technologies Co., Ltd. All rights reserved.
H3C WS5820-28X-POE-WiNet uptime is 0 weeks, 0 days, 0 hours, 52 minutes
Last reboot reason : User reboot
Boot image: flash:/ws5800winet-cmw710-boot-r6361.bin
Boot image version: 7.1.070, Release 6361
  Compiled Dec 26 2023 11:00:00
System image: flash:/ws5800winet-cmw710-system-r6361.bin
System image version: 7.1.070, Release 6361
Slot 1:
Uptime is 0 weeks,0 days,0 hours,52 minutes
WS5820-28X-POE-WiNet with 1 Processor
BOARD TYPE:         WS5820-28X-POE-WiNet
DRAM:               512M bytes
FLASH:              256M bytes
PCB 1 Version:      VER.B
Bootrom Version:    154
CPLD 1 Version:     001
Release Version:    H3C WS5820-28X-POE-WiNet-6361
zhiliao_O5l1OW 知了小白
旧版6331版本可以正常备份,最新6361提示TFTP error
命令不一样了吧  可能  没用这个功能
应该是软件版本bug,用tftp命令也提示找不到文件。。。。
zhiliao_O5l1OW 发表时间:2025-01-05 更多>>
命令一样
粉丝:105人 关注:1人
检查TFTP服务器状态,服务状态及账号密码权限
