华三s5500怎么查看交换机有没有密码
2025-02-24提问
  • 0收藏,2180浏览
华三s5500怎么查看交换机有没有密码,怎么恢复出厂设置,恢复出厂设置以后有没有默认密码,我是用crt登录的交换机
1、以下是配置console密码的参考命令:有没有配置密码,可以看下有没有相关配置
(1)用户名密码登录:
local-user admin
password simple admin
service-type ter
authentication level 15
line console 0
authentication-mode scheme
(2)密码登录:
line console 0
authentication-mode password
set authentication password simple admin
user pri level 3
2、交换机现在能登录命令行吗?可以的话,reset sa或者reset factory-default清空配置或者恢复出厂,恢复出厂后除了web管理的个别型号外,没有默认密码。
3、如果不能登录命令行了
通过conlse线crt软件连接并登陆设备,然后把设备断电重启。控制台上会打印如下信息,当出现“press Ctrl B”时候快速按住“Ctrl B” 进入botroom菜单
System is starting...
Press Ctrl D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl B to enter extended boot menu...
BotWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
      按住“Ctrl B”进入如下菜单。选择<6> Skip Current System Configuration跳过当前配置启动,不同设备可能不是数字6,
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl Z: Access EXTEND-ASSISTANT MENU
Ctrl F: Format File System
Enter your choice(0-9): 6
Flag Set Success.
然后输入0重启设备
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
Press ENTER to get started.
3.2 如果不需要之前的配置信息的话
操作步骤:跳过启动文件后直接保存当前配置,再重启。
<H3C>save
(To leave the existing filename unchanged, press the enter key):(输入回车)
Configuration is saved to device successfully.
<H3C>reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
