interface Ethernet0/0
port link-mode route
nat outbound address-group 30
ip address 117.141.x.x 255.255.255.192
load-bandwidth 50000
qos car inbound carl 6 cir 100000 cbs 1250000 ebs 0 green pass red discard
qos car inbound carl 7 cir 100000 cbs 1250000 ebs 0 green pass red discard
qos car inbound carl 8 cir 100000 cbs 1250000 ebs 0 green pass red discard
qos car inbound carl 9 cir 100000 cbs 1250000 ebs 0 green pass red discard
qos car inbound carl 5 cir 100000 cbs 1250000 ebs 0 green pass red discard
dns server 114.114.114.119
dns server 114.114.115.119
ip user-based-sharing enable
interface Ethernet0/1
nat outbound address-group 21
nat server protocol tcp global 124.227.x.x www inside 172.17.19.214 www
nat server protocol tcp global 124.227.x.x 8000 inside 172.17.19.214 8000
nat server protocol tcp global 124.227.x.x 554 inside 172.17.19.214 554
ip address 124.227.x.x 255.255.255.248
load-bandwidth 20000
qos apply policy PolicyLimitInput-983041 inbound
qos car inbound carl 1 cir 20000 cbs 255750 ebs 0 green pass red discard
qos car inbound carl 2 cir 20000 cbs 256000 ebs 0 green pass red discard
qos car inbound carl 3 cir 20000 cbs 256000 ebs 0 green pass red discard
qos car inbound carl 4 cir 20000 cbs 256000 ebs 0 green pass red discard
qos car inbound carl 10 cir 20000 cbs 1250000 ebs 0 green pass red discard
(0)
V5平台MSR你得注意路由,双WAN接入对于内网接入上网可以做基于用户得负载分担,但是如果你做端口映射,默认路由又是E0/0出去肯定不行,端口映射从E0/1,回包回到E0/0,做一个本地策略路由
(0)
ip route-static 0.0.0.0 0.0.0.0 Ethernet0/0 117.141.x.x
ip route-static 0.0.0.0 0.0.0.0 Ethernet0/1 124.227.x.x
路由是这么做,感觉是有问题的,端口映射回包不正常
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
要对内网服务器做策略路由,强制从0/1出口出?策略路由怎么做?
从目前配置看是只有一个口做了映射啊,先定义acl,匹配服务器源地址,policy-based-route test permit node 10,if-match acl 3000,apply ip-address next-hop 124.227.x.x,内网接口下ip policy-based-route test
如果内网要通过私网访问,需要先用ACL定义内网互访的流量,然后policy-based-route里面定义一个node,if-match acl,不做apply动作。。。这个node编号要小于上面那个。。
