F100-C-G2的l2tp连接不上
2018-10-20提问
  • 1收藏,774浏览
粉丝:2人 关注:1人
我把 F100-C-G2替换了F100-C-G,新防火墙的上联IP端口和就防火墙的IP地址一样,旧防火墙已下架不联网,排除IP冲突,路由器还是保持 udp 500、1701、4500 的端口转发。由于 F100-C-G2的web界面看不到 l2tp,就按照官网文档 的1.8.2 小节配置。 http://www.h3c.com/cn/d_201807/1097501_30005_0.htm    。没见命令报错,账号密码和旧防火墙的账号密码一样,我和同事都用外面的网络,就是连接不上,配置如下,其中的专线IP和密码我以 手打马赛克加密:
 version 7.1.064, Release 9510P03
 sysname H3C
 clock timezone Lisbon add 00:00:00
 clock protocol none
context Admin id 1
ip vpn-instance management
 route-distinguisher 1000000000:1
 vpn-target 1000000000:1 import-extcommunity
 vpn-target 1000000000:1 export-extcommunity
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 ip pool aaa 172.18.10.1
 ip pool aaa 172.18.10.10 172.18.10.20
 ip pool aaa gateway 172.18.10.1
 dhcp enable
 password-recovery enable
vlan 1
vlan 14
object-group ip address 50-60
 0 network subnet 172.18.50.0 255.255.255.0
 10 network subnet 172.18.60.0 255.255.255.0
object-group ip address neiwang
 0 network subnet 192.168.2.0 255.255.255.0
dhcp server ip-pool 14
 gateway-list 192.168.4.1
 network 192.168.4.0 mask 255.255.255.0
 dns-list 114.114.114.114
interface Virtual-Template1
 ppp authentication-mode chap domain system
 remote address pool aaa
 ip address 172.18.10.1 255.255.255.0
interface NULL0
interface Vlan-interface14
 ip address 192.168.4.1 255.255.255.0
interface GigabitEthernet1/0/0
 port link-mode route
 combo enable fiber
 ip binding vpn-instance management
 ip address 192.168.0.1 255.255.255.0
 combo enable fiber
 description GigabitEthernet1/0/2 Interface、上联路由器
 ip address 192.168.1.3 255.255.255.0
 nat outbound
 description GigabitEthernet1/0/3 Interface、下联核心三层
 ip address 192.168.2.3 255.255.255.0
interface GigabitEthernet1/0/5
 description GigabitEthernet1/0/5 InterfaceVLAN80测试
 ip address 172.18.8.215 255.255.255.0
 nat outbound
interface GigabitEthernet1/0/9
 ip address dhcp-alloc
interface GigabitEthernet1/0/4
 port link-mode bridge
 port access vlan 14
interface GigabitEthernet1/0/6
 port access vlan 14
interface GigabitEthernet1/0/8
 port access vlan 14
interface GigabitEthernet1/0/10
 port access vlan 14
object-policy ip Local-Trust
 rule 0 pass
object-policy ip Trust-Local
 rule 0 pass
object-policy ip Trust-Untrust
 rule 0 pass
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/3
 import interface Vlan-interface14
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/2
 import interface GigabitEthernet1/0/5
 import interface GigabitEthernet1/0/7
 import interface GigabitEthernet1/0/11
 import interface Virtual-Template1
security-zone name Management
 import interface GigabitEthernet1/0/0
 import interface GigabitEthernet1/0/9
zone-pair security source Local destination Trust
 object-policy apply ip Local-Trust
 packet-filter 3333
 packet-filter 3001
zone-pair security source Trust destination Local
 object-policy apply ip Trust-Local
 packet-filter 3333
 packet-filter 3001
zone-pair security source Trust destination Untrust
 object-policy apply ip Trust-Untrust
 packet-filter 3000
zone-pair security source Untrust destination Local
 packet-filter 2000
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class vty
line aux 0
line con 0
 authentication-mode scheme
line vty 0 63
 ip route-static 0.0.0.0 0 GigabitEthernet1/0/2 192.168.1.2
 ip route-static 0.0.0.0 0 GigabitEthernet1/0/5 172.18.8.1
 ip route-static 172.18.5.0 24 192.168.2.1
 ip route-static 172.18.6.0 24 192.168.2.1
 ip route-static 172.18.7.0 24 192.168.2.1
 ip route-static 172.18.8.0 24 192.168.2.1
 ip route-static 172.18.12.0 24 192.168.2.1
 ip route-static 172.18.13.0 24 192.168.2.1
 ip route-static 172.18.18.0 24 192.168.2.1
 ssh server enable
acl advanced 3000
 rule 0 permit ip source 192.168.2.0 0.0.0.255
acl advanced 3001
 rule 0 permit ip
acl advanced 3333
 rule 0 permit ip
domain system
 authentication ppp local
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit ssh 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash 手打马赛克xxxxxxx
 service-type ssh terminal http https
 authorization-attribute user-role level-3
local-user root class manage
 service-type telnet terminal http https
local-user vpnuser class network
 password cipher 手打马赛克xxxxxxx
 service-type ppp
l2tp-group 1 mode lns
 allow l2tp virtual-template 1
 undo tunnel authentication
 tunnel name LNS
 l2tp enable
 ip http enable
 ip https enable
return
寂东 九段
粉丝:141人 关注:3人
有两点:
1:
 packet-filter 2000
没有看到acl 2000的内容,确保acl 2000里的允许规则包含了从外部到内部的vpn访问通信
2:增加域间策略:
zone-pair security source  Local   destination Local
 packet-filter 3001
V5平台了不需要这样做,V7平台安全性提高了,同域之间通信也需要做策略,加上这条策略再试试
是上不了网还是什么问题
在外面接入不了内网,连接不上
烟花里的尘埃 发表时间:2018-10-20
顺便问问这一段配置是怎么删除,我在web界面看不到了 object-group ip address 50-60 0 network subnet 172.18.50.0 255.255.255.0 10 network subnet 172.18.60.0 255.255.255.0 # object-group ip address neiwang 0 network subnet 192.168.2.0 255.255.255.0
undo object-group ip address 50-60删除此配置
zhiliao_G8mAp 发表时间:2018-10-20
粉丝:2人 关注:1人
提示这个
将untrust到local local到untrust的域间策略放通一下,保证外网能够ping通公网口的地址。
放通了,不过还是ping不通 公网 IP
我看到虚拟接口还是 down 状态的
我致电售后工程师,他发了个精简版的配置,我再增加一段关于 1701端口的配置,才能连接上
