MSR2600 设置L2TP over IPsec PC到站点 问题
2018-10-23提问
  • 1收藏,1187浏览
按照以下方式配置
<WiNet_0.H3C>display current-configuration
 version 5.20, Release 2516P15
 sysname H3C
 clock timezone Beijing add 08:00:00
 l2tp enable
 domain default enable system
 dns resolve dns proxy enable
 telnet server enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable ntdp hop 8
cluster enable
 port-security enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
 ip pool 0 192.168.10.5 192.168.10.100
ike proposal 1
 encryption-algorithm aes-cbc 256
 dh group2
 authentication-algorithm md5
ike peer zilliz_hz
 exchange-mode aggressive
 proposal 1
 pre-shared-key cipher xxxxx
 nat traversal
ipsec transform-set zilliz_hz
 encapsulation-mode transport
 transform esp
 esp authentication-algorithm sha1
 esp encryption-algorithm aes-cbc-128
ipsec policy-template 1048576.1_t 1
 connection-name zilliz_hz
 ike-peer zilliz_hz
 sa duration traffic-based 1843200
 sa duration time-based 3600
 reverse-route
ipsec policy 1048576 1 isakmp template 1048576.1_t
dhcp server ip-pool vlan1 extended
 network ip range 192.168.1.2 192.168.1.254
 network mask 255.255.255.0
 gateway-list 192.168.1.1
 dns-list 192.168.1.1
user-group system
 group-attribute allow-guest
local-user zilliz_hz
 password cipher xxxxx
 authorization-attribute level 2
 service-type ppp
cwmp
 undo cwmp enable
l2tp-group 1
 undo tunnel authentication
 allow l2tp virtual-template 0
 tunnel password cipher xxxx
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
interface Virtual-Template0
 ppp authentication-mode chap domain system
 remote address pool
 ip address 192.168.10.1 255.255.255.0
结果连接时,日志打印
-Src addr=221.104.213.100-Dst addr=180.169.38.214-I_COOKIE=685160ac09f2b82e-R_COOKIE=6daee43382715e39-Cause=No proposal is chosen-Payload=PROPOSAL; IKE packet dropped.
未连接成功
No proposal is chosen 已经提示了,两边的ike proposal不匹配,不能完成协商,核对一下两边的ike porposal内容是否一致
我安卓都是怎么可以设置ike porposal?
zhiliao_AANVR 发表时间:2018-10-23
回复zhiliao_AANVR:
安卓的不懂怎么搞,最好百度看看有没有设置介绍什么的,ipsec要通,参数必须要对应才可以
风干工程师肉干要不要 发表时间:2018-10-23
我在ubuntu下用sudo ike-scan 180.169.38.234 获取ike porposal,没法获取。
回复zhiliao_AANVR:
不懂,没接触过ubuntu建立ipsec这种情况。。。
zhiliao_AANVR 知了小白
有人能帮忙解决下么?
