WA4320-ACN-SI转换成FIT AP
  • 1收藏,1490浏览
现有WX2540H和WA4320-ACN-SI FAT AP模式,怎样转换成FTI AP并在AP上注册?
寂东 九段
粉丝:225人 关注:3人
1,胖ap转换成瘦ap,用户视图下:<H3C>ap-mode fit
ap注册,首先配置好网络连接,在ac上划个vlan,并启用dhcp,是ap接入的端口都在此vlan中,然后ac上开启自动注册和自动固化即可:
2,AC上建立无线模板:
wlan service-template 1
 ssid CASVC
 akm mode psk
preshared-key pass-phrase cipher xxxx   (无线接入密码)
 cipher-suite ccmp
 security-ie rsn
 service-template enable
3,在AC上开启自动注册:
 wlan auto-ap enable
 wlan auto-persistent enable ,
4, 然后进入ap组,进入指定的ap型号,在进入射频口绑定模板
wlan ap-group default-group
 ap-model WA4320-ACN-si
 radio 1
radio enable
 service-template 1 vlan  x   (业务vlan)
 radio 2
 radio enable
在web上切换FIT AP后 AP启动显示 Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fit.bin! The main application file does not exist--flash:/wa4300s_fit.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin! The secure application file does not exist--flash:/secure.bin! Booting App fails!
zhiliao_XQyNC 发表时间:2018-11-24
回复zhiliao_XQyNC:
是的,切换成功了,启动的时候在找fit版本的软件,但是现在ap中还没有,配置好网络连接后,ap会从ac上下载版本软件和配置
寂东 发表时间:2018-11-24
dhcp获取成功了,但现实获取不到AC的地址,option 43 is:0 下载不到固件
我在dhcp服务里配置了option 43 ip-address 192.168.1.254 AP还是显示为0
我把optione 43 配置成16进制 AP获取到了, Trying to get the IP address from the DHCP server...... DHCP server's IP address is 192.168.1.254 Client's assigned address is 192.168.1.1 DNS domain name got from DHCP server is DNS server's IP address is 0.0.0.0 Default Gateway's IP address is 192.168.1.254 This client's subnet mask is 255.255.255.0 The length of option 43 is: 9 Change State : Idle to Broadcast Discovery Change State : Broadcast Discovery to Unicast Discovery Use Option 43: Getting AC's IP Address 192.168.1.254 Change State : Unicast discovery to Sulking Change State : Idle to Broadcast Discovery Change State : Broadcast Discovery to Unicast Discovery Use Option 43: Getting AC's IP Address 192.168.1.254 Change State : Unicast discovery to Sulking Can't download the image from network, please check the network settings The system will reboot
回复zhiliao_XQyNC:
192.168.1.254是ac的地址吗 ?
寂东 发表时间:2018-11-24
回复寂东:
是的,这是我创的vlan100的IP,后来我改用vlan1,IP地址192.168.0.100与AP连接,还是相同的结果
回复zhiliao_XQyNC:
ac上启用自动注册了吗?我回复中第三步那两个命令
寂东 发表时间:2018-11-24
回复寂东:
OK了,感谢大神
回复zhiliao_XQyNC:
你是不是忘记点事,还没点采纳吧
寂东 发表时间:2018-11-24
粉丝:8人 关注:5人
登录ap的web界面--高级配置-点击形态切换,或者登录ap的命令行执行ap-mode fit
