现有WX2540H和WA4320-ACN-SI FAT AP模式,怎样转换成FTI AP并在AP上注册?
(0)
1,胖ap转换成瘦ap,用户视图下:<H3C>ap-mode fit
ap注册,首先配置好网络连接,在ac上划个vlan,并启用dhcp,是ap接入的端口都在此vlan中,然后ac上开启自动注册和自动固化即可:
2,AC上建立无线模板:
wlan service-template 1
ssid CASVC
akm mode psk
preshared-key pass-phrase cipher xxxx (无线接入密码)
cipher-suite ccmp
security-ie rsn
service-template enable
3,在AC上开启自动注册:
wlan auto-ap enable
wlan auto-persistent enable ,
4, 然后进入ap组,进入指定的ap型号,在进入射频口绑定模板
wlan ap-group default-group
ap-model WA4320-ACN-si
radio 1
radio enable
service-template 1 vlan x (业务vlan)
radio 2
radio enable
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
在web上切换FIT AP后 AP启动显示 Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fit.bin! The main application file does not exist--flash:/wa4300s_fit.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin! The secure application file does not exist--flash:/secure.bin! Booting App fails!
是的,切换成功了,启动的时候在找fit版本的软件,但是现在ap中还没有,配置好网络连接后,ap会从ac上下载版本软件和配置
dhcp获取成功了,但现实获取不到AC的地址,option 43 is:0 下载不到固件
我在dhcp服务里配置了option 43 ip-address 192.168.1.254 AP还是显示为0
我把optione 43 配置成16进制 AP获取到了, Trying to get the IP address from the DHCP server...... DHCP server's IP address is 192.168.1.254 Client's assigned address is 192.168.1.1 DNS domain name got from DHCP server is DNS server's IP address is 0.0.0.0 Default Gateway's IP address is 192.168.1.254 This client's subnet mask is 255.255.255.0 The length of option 43 is: 9 Change State : Idle to Broadcast Discovery Change State : Broadcast Discovery to Unicast Discovery Use Option 43: Getting AC's IP Address 192.168.1.254 Change State : Unicast discovery to Sulking Change State : Idle to Broadcast Discovery Change State : Broadcast Discovery to Unicast Discovery Use Option 43: Getting AC's IP Address 192.168.1.254 Change State : Unicast discovery to Sulking Can't download the image from network, please check the network settings The system will reboot
192.168.1.254是ac的地址吗 ?
是的,这是我创的vlan100的IP,后来我改用vlan1,IP地址192.168.0.100与AP连接,还是相同的结果
ac上启用自动注册了吗?我回复中第三步那两个命令
OK了,感谢大神
你是不是忘记点事,还没点采纳吧
