H3C S5500-28C-SI 堆叠
2017-10-21提问
  • 1收藏,2251浏览
小白 零段
两台相同配置的H3C S5500-28C-SI 如何堆叠?对已划分的VLAN会不会有影响?
以下是配置文件:
 version 5.20, Release 2202P19
 sysname WNDJ_hexin5500
 domain default enable system
 telnet server enable
 undo cluster enable
acl number 3000
 rule 0 deny ip source 192.169.0.0 0.0.0.255 destination 10.10.12.0 0.0.0.255
vlan 1
vlan 10
 description To_Internet
vlan 20
 description To_Neiwang
vlan 30
 description To_Neiwang_1wangduan
vlan 40
 description To_Neiwang_3wangduan
vlan 100
 description Link_to_UTM200-CM
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
traffic classifier Not_to_Internet operator and
 if-match acl 3000
traffic behavior Not_to_Internet
 filter deny
qos policy Not_to_Internet
 classifier Not_to_Internet behavior Not_to_Internet
user-group system
local-user h3c
 password simple wndj1931
 authorization-attribute level 3
 service-type telnet
local-user wndjh3c5500
 password cipher 9_ZL9"4]%73Q=^Q`MAF4<1!!
 service-type telnet
interface NULL0
interface Vlan-interface10
 ip address 192.169.2.1 255.255.255.0
interface Vlan-interface20
 ip address 192.169.0.1 255.255.255.0
interface Vlan-interface30
 ip address 192.169.1.1 255.255.255.0
interface Vlan-interface40
 ip address 192.169.3.1 255.255.255.0
interface Vlan-interface100
 description Link_to_UTM-CM
 ip address 10.10.12.2 255.255.255.0
 port access vlan 100
 port access vlan 10
 port access vlan 10
interface GigabitEthernet1/0/4
 port access vlan 10
interface GigabitEthernet1/0/5
 port access vlan 10
interface GigabitEthernet1/0/6
 port access vlan 20
interface GigabitEthernet1/0/7
 port access vlan 20
interface GigabitEthernet1/0/8
 port access vlan 20
interface GigabitEthernet1/0/9
 port access vlan 20
interface GigabitEthernet1/0/10
 port access vlan 20
interface GigabitEthernet1/0/11
 port access vlan 30
interface GigabitEthernet1/0/12
 port access vlan 30
interface GigabitEthernet1/0/13
 port access vlan 30
interface GigabitEthernet1/0/14
 port access vlan 30
interface GigabitEthernet1/0/15
 port access vlan 30
interface GigabitEthernet1/0/16
 port access vlan 40
interface GigabitEthernet1/0/17
 port access vlan 40
interface GigabitEthernet1/0/18
 port access vlan 40
interface GigabitEthernet1/0/19
 port access vlan 40
interface GigabitEthernet1/0/20
 port access vlan 40
interface GigabitEthernet1/0/21
 port access vlan 10
interface GigabitEthernet1/0/22
 port access vlan 20
interface GigabitEthernet1/0/23
 port access vlan 10
interface GigabitEthernet1/0/24
 port access vlan 10
interface GigabitEthernet1/0/25
 shutdown
interface GigabitEthernet1/0/26
 shutdown
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
 ip route-static 0.0.0.0 0.0.0.0 10.10.12.1
 snmp-agent
 snmp-agent local-engineid 800063A20300E0FC123456
 snmp-agent community read public
 snmp-agent community write private
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 192.168.0.2 params securityname public
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
粉丝:12人 关注:7人
S5500-28C-SI需要万兆扩展模块才能做IRF堆叠,目前配置里面都是自带千兆口,不支持。
那可以使用 Stack 方式堆叠吗
小白 发表时间:2018-09-17
回复小白:
不支持哦
战五渣 发表时间:2018-09-22
回复战五渣:
如果没有万兆模块还有其他堆叠方式吗?两台S5500-28C-SI。谢谢
小白 发表时间:2018-09-25
回复小白:
没有了
战五渣 发表时间:2018-09-25
xiaoyu 九段
粉丝:69人 关注:0人
官网有完整的案例。设备修改member id号,端口号会变化,所以在做IRF之前,自己把配置都先备份。做完IRF之后再进行配置。
http://www.h3c.com/cn/Service/Document_Center/Switches/Catalog/S5500/S5500-EI/Configure/Operation_Manual/H3C_S5500-EI[SI]_CG-Release_2220-6W100/02/
H3C S5500-28C-SI 支持IRF吗,可以用Stack做简单堆叠吗
小白 发表时间:2017-10-21
