MSR路由器3G+IPsec与4G+IPsec的配置
2017-10-31提问
  • 1收藏,2121浏览
求教下,MSR路由器3G+IPsec与4G+IPsec的配置有什么区别?
比如说下面的3G+IPsec的配置,改成使用4G+IPsec后,需要怎么需改?
 dialer-group 1 rule ip permit
 standby routing-group 1 rule ip 10.51.0.0 24
controller Cellular0/0
controller Cellular4/0
 serial-set 0
interface Serial4/0:0
 ppp chap password cipher $3/36ptePISfxfLy5t77Lk=
 ppp chap user card
 ppp ipcp dns request
 dialer circular enable
 dialer-group 1
 dialer number #777
 ip address ppp-negotiate
 packet-filter 3100 outbound
 ipsec apply policy 3gpolicy
 ip route-static 10.50.0.0 30 Serial4/0:0
 ip route-static 10.51.0.0 24 Serial4/0:0
 ip route-static 218.6.246.11 32 Serial4/0:0
 info-center loghost 10.51.0.248
acl advanced 3100
 rule 0 permit icmp
 rule 10 permit ip destination 218.6.246.11 0
 rule 20 permit tcp source-port eq 22
 rule 65534 deny ip
acl advanced name ipsectunnel
 rule 0 permit ip source 10.51.135.64 0.0.0.63 destination 10.50.0.0 0.0.0.3
 rule 5 permit ip source 10.51.135.64 0.0.0.63 destination 10.51.0.0 0.0.0.255
pki domain 3gdomain
 ca identifier SFCASRV-CA
 certificate request url http://10.51.0.249/certsrv/mscep/mscep.dll
 certificate request from ra
 certificate request entity 3gentity
 certificate request polling count 100
 certificate request polling interval 5
 certificate request mode auto
 public-key rsa general name 3grsa
 undo crl check enable
pki entity 3gentity
 common-name 644-1
 country CN
 locality ZhangXuBaZhan
 fqdn branch
 organization-unit 154LeYa
 state sichuan
cwmp
 cwmp enable
 cwmp acs password cipher $3$+47EESE7tLrLO6cp+edn/0xuHy4KF9N4SVJslD8=
 cwmp acs url http://10.51.0.248:9090
 cwmp acs username scits
 cwmp cpe connect interface Vlan-interface10
 cwmp cpe inform interval enable
 cwmp cpe password cipher $3$8GAF1fRI77KyENB/hUnFGKoGfWX70UI04g61buw=
 cwmp cpe username scits
ipsec transform-set 3gtransform
 esp encryption-algorithm aes-cbc-128
 esp authentication-algorithm sha1
ipsec policy 3gpolicy 1 isakmp
 security acl 3001
 remote-address 218.6.246.11
 ike-profile 3gprofile
 ike dpd interval 5 retry 3 on-demand
ike profile 3gprofile
 certificate domain 3gdomain
 exchange-mode aggressive
 local-identity fqdn branch
 match remote identity fqdn center
 proposal 1
ike proposal 1
 authentication-method rsa-signature
 authentication-algorithm md5
jlubao 五段
粉丝:5人 关注:3人
三、 配置步骤: 适用设备和版本:MSR系列、R2514P10及以后的版本。 MSR路由器配置概要说明: # 切换为4G接口。 如果不存在Cellular-ethernet 0/0接口,只有Cellular0/0接口,说明USB接口工作在PPP模式,需要切换到以太模式。 [Router] card-mode slot 0 ethernet # 配置4G接口。 [Router]interface Cellular-Ethernet0/0 [Router-Cellular-Ethernet0/0]dialer enable-circular [Router-Cellular-Ethernet0/0]dialer-group 1 [Router-Cellular-Ethernet0/0]dialer timer autodial 5 [Router-Cellular-Ethernet0/0]dialer number *99# autodial // 自动拨号 [Router-Cellular-Ethernet0/0]nat outbound // 必须配置nat。 [Router-Cellular-Ethernet0/0]ip address dhcp-alloc // dhcp方式获取IP地址。 # 配置拨号规则和DNS代理。 [Router]dialer-rule 1 ip permit [Router]dns resolve [Router]dns proxy enable #配置内网接口的IP地址。 [Router] interface GigabitEthernet0/0 [Router-GigabitEthernet0/0] ip address 192.168.100.68 255.255.255.0 通过Web管理Modem说明: PC的IP地址是192.168.100.4,PC的网关和DNS服务器都设置为路由器内网接口的地址(192.168.100.68),Modem的IP地址是192.168.8.1 在Web地址栏中输入http://192.168.8.1,可以管理Modem。 注意:Cellular-ethernet接口的配置不完整,接口没有up时不能通过Web管理Modem。 查看Modem给Cellular-ethernet接口分配的IP地址,Modem的IP地址等信息,请执行命令:display dhcp client verbose。 配置关键点及注意事项
那切换为4G后,是不是不需要配置ppp认证了?还有,IPsec直接调用就可以了吗,还需要修改什么吗?
zhiliao_12776 发表时间:2017-10-31
