S6300 NTP同步后时间错误
2017-11-03提问
  • 1收藏,2458浏览
NTP同步状态为已同步,但是时间不正确!
配置如下:
clock protocol ntp
ntp-service enable
ntp-service source Vlan-interface10
ntp-service unicast-server 202.108.6.95
<T1B2-Office-S6300>dis ntp status
Clock status: synchronized
Clock stratum: 3
System peer: 202.108.6.95
Local mode: client Reference
clock ID: 202.108.6.95
Leap indicator: 00
Clock jitter: 0.000443 s
Stability: 0.000 pps
Clock precision: 2^-17
Root delay: 41.30554 ms
Root dispersion: 53.13110 ms
Reference time: dda6a833.db1daca9 Fri, Nov 3 2017 8:32:51.855
<T1B2-Office-S6300>display clock
08:37:30 UTC Fri 11/03/2017
当前实际已经是下午了,时间不对!
<T1B2-Office-S6300>display ntp-service
trace Server 127.0.0.1
Stratum 3, jitter 0.0000, synch distance 0.0414.
Server 202.108.6.95 Stratum 2, jitter 0.3350, synch distance 0.8850.
Server 10.6.63.22: Timeout. RefID 10.6.63.22
粉丝:12人 关注:7人
只同步时间,不同步时区,可以修改下时区。
[H3C]clock timezone beijing add 08:00:00
时区配置不对吧,应该是差了8个小时
zhiliao_44322 知了小白
已解决,更换了一个时钟地址,添加了时区!
